Up and down for 3 seconds. function 1 should be option 1.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
SOURCE: My desk top hp pavillion will not turn on
Hold the power button in on the computer for 5 seconds. Wait another 5 seconds. Now hit the power button as you normally would to turn the PC on. It should boot normally.
SOURCE: My MX6453 won't turn on
You may have turned off the LCD screen. After you turn the computer on, hit Fn+F4 keys and then wait a moment. Then try it again. The F4 key cycles the video output through three settings: from LCD only, to external monitor only, to LCD + external video. You could also try connecting the video output on the back of the computer to a different monitor to see if it's a screen problem on the laptop of a broken video card.
The F4 key has the blue icons for a little TV screens. The Fn key is in the lower left corner.
About two weeks ago I started getting a "Catalyst Control Center" error about the video driver for my MX6453, so I assume there was some sort of update that was pushed through Microsoft or from ATI that changed display settings or drivers. Your computer may have had an extreme reaction to the software update if you accepted it. I did not accept the update and my computer works fine.
You can also try to boot in safe mode which should prevent the advanced drivers from installing. Basically you hit F8 as it's powering up. See here for more info: http://www.pchell.com/support/safemode.shtml
SOURCE: screen won't turn on - power button continues to f...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed LG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
SOURCE: The stove is stuck on
You can get Whirlpool manuals from http://www.whirlpool.com/custserv/index.jsp
Just got it from there:
The temperature is preset at Fahrenheit, but can be changed to
Celsius.
Style 1 - Electronic Oven Control
To change: Press and hold PRECISE CLEAN for 5 seconds, and
"TEMPERATURE UNIT CELSIUS" will appear in the display.
Repeat to change back to Fahrenheit.
To exit mode, press OFF/CANCEL.
Styles 2, 3 & 4 - Electronic Oven Controls
To change: Press and hold BROIL for 5 seconds. A tone will
sound and "°C" or "°F" will appear on the display. Repeat to
