Hi Brendan, Hit menu, then Navi set up, then Cailbration, then clock set. There you can change the hour only, the system will only set the minutes automaticly.
Also - make sure you're NavData is set to the region you are in. I had to do that when I first got mine. You'll see a map of the USA and you can change the predetermined regions. I do not recall off the top of my head how to get to that screen. I am NOT sure if that has ANYTHING to do with the clock & time zones.
Thanks for that David, Unfortunately I live in New Zealand and mine is a Japanese import so everything is in Japanese. If I cld see some photos of the buttons I have to press would make it easier, even better I wish I cld change the language of it as I know it has english characters. Cheers anyway
Hi Brendan, Try going to You Tube:-
https://www.youtube.com/watch?v=mF2VLleS...
You might have to enter it in your search engine yourself
Hope this helps
Kind regards
David
I forgot to mention, that's not the video you watch. If you look to the right of the screen, you will see a video
"how to change the language from Japanese to English"
David
SOURCE: Setting the clock on an Alpine CDM7874 car radio
Users Manual is here;
http://vault.alpine-usa.com/products/documents/OM_CDM-7874.PDF
Clock setting(s) are on page 10.
Best of Luck.
SOURCE: Alpine CDE-9843
Page 16 of the manual:
http://vault.alpine-usa.com/products/documents/CDE-9841,%2043,%2045%20OM.PDF
Setting Time
1 In the Clock priority mode, press and hold
TITLE for at least 2 seconds while the time is
displayed.
The time indication will blink.
2 Turn the Rotary encoder (CDE-9845/CDE-9843
only) or press 4 and 3 (CDE-9841 only) to adjust
the hours while the time indication is blinking.
3 When the hour has been adjusted, press the
Rotary encoder (CDE-9845/CDE-9843 only) or
press MODE (CDE-9841 only).
4 Turn the Rotary encoder (CDE-9845/CDE-9843
the minutes while the time indication is blinking.
The time is automatically set 5 seconds after the minute
adjustment. The time can also be manually set by
pressing the Rotary encoder (CDE-9845/CDE-9843 only)
or press MODE (CDE-9841 only).
• To synchronize the clock to another clock/watch or radio time
announcement, press and hold the Rotary encoder (CDE-9845/
CDE-9843 only) or press and hold MODE (CDE-9841 only) for at
least 2 seconds after setting the “hour.” Minutes will reset to 00. If
the display shows over “30” minutes when you do this, the time
will advance one hour.
SOURCE: clock setting on alpine iva-w200
Copied from Alpine-usa.com support page:
Setting item: CLOCK ADJUST
Further setting items : HOUR / MINUTE / TIME ADJUST
Setting content: 1-12 / 0-59 / RESET
• The clock-adjusting mode is canceled when the power is turned off,
when [RETURN] or [CONTROL] is touched.
Setting item: DAYLIGHT SAVING TIME
Setting content: OFF / ON
Setting the Time
HOUR: Adjust the hour.
MINUTE: Adjust the minute.
RESET: If the clock shows less than 30 minutes past, the
minute will be “: 0”; more than 30, the hour
advances.
Setting Daylight Saving Time
ON: Place the Summer Time mode ON. The time advances by
one hour.
OFF: Return to the ordinary time.
SOURCE: how do I set the clock in Alpine CDE-9872 CD receiver?
From the Owners Manual for the CDE-9872:
FixYa won't allow images larger than 150k, so that's why this is a little blurry.
I hope this helps! Please post rating, if it does.
Regards,
Char1ieJ
SOURCE: setting the clock
hold down the mute button until the screen says clock adjustment if it doesn't saw the use the volume until it does. the press the ENT button in the upper left hand corner then the hour # should flash use the volume button to adjust then press the ENT button the change the minute and when the corect time is in press mute untill the screen is back to normal
