Question about KitchenAid Food Processors
KFP0711 Kitchenaid food processor won’t turn on even when put together. Just opened and never been used.
Posted by Randi Thornton on
Ross Keen
  • KitchenAid Master
  • 1,364 Answers
Read the handbook and make certain you are assembling the bowl, lid and pusher correctly, they can all play a part in activating the safety mechanisms that put the appliance in the mode that will allow it to be started.
Posted on Nov 24, 2017
5 Related Answers
QuietRiot
  • 145 Answers
SOURCE: Need to clean inside of handle on KitchenAid food processor
The plastic for the work bowl / handle is molded and one piece and cannot be disassembled. My best recommendation is to call Kitchenaid customer service to see what recommendations they have. Within one year warranty, they may replace the work bowl at no cost.
Their toll-free number is: 1-800-541-6390.
Posted on Jul 07, 2009
Anonymous
  • 89 Answers
SOURCE: Need owners manual for kitchenaid food processor model # KFP740CR
http://www.kitchenaid.com/flash.cmd?/#/page/home
this site should help you out.
one thing, you can chop onions without crying.
Posted on Nov 08, 2009
John McPherson
  • 1212 Answers
SOURCE: My kitchenaid food processor won't work
Does the actuator push down far enough to catch the button at the bottom? I repaired one simply by adding a vinyl screw cover to the top of the button so it was tall enough to be reached by the actuator.
Posted on Dec 20, 2011
Testimonial: "really helpful thanks"
Steve Papp
  • 1010 Answers
SOURCE: where do you turn on the kitchenaid mini food processor
I think it will start, when you close the lid
Posted on Mar 29, 2013
t_w_miller_5
Tom M
  • 90 Answers
SOURCE: Very frustrated with kitchenaid food processor - using any slicing disk only the first batch of food works, when you put in the 2nd batch nothing happens
Mine is older and works fine once I realized bowl has to be snapped into place before the cover and then the cover has to be locked in. This activates a small button at the base of the bowl that activates a safety switch.
Posted on Jan 03, 2015
My food processor blade keeps popping up (loose) when I put food into it.
You will probably need to replace the sleeve on the motor shaft and the blade. If overloaded the shaft can spin inside the blade which wrecks the connection between them. Replacing both together is the correct solution.
May 16, 2014 | KitchenAid Chefs Chopper KFC3100 3 Cups...
Dec 20, 2011 | KitchenAid Food Processors
Kitchen Aid Little Ultra Power, 4 yrs old, suddenly stopped.
I HAVE A BASE UNIT WITH NO MIXING BOWL,
HARDLY USED , CAN PURCHASE CHEAP
RESPOND TO [email protected]
Jul 13, 2009 | KitchenAid KFP450 Ultra Power 7 Cups Food...
I have a kitchenaid food processor and the bowl is tightly set on the right side of center. I can't straighten it out and when I try to move it, it sounds like I'm cracking plastic. It won't run! Any...
Items required:
-dishwasher
-detergent
-lemonade or other citric liquid
-poochy
-skillz
Step 1:
gently position poochy around tube in center of bowl. Fill halfway with lemonade or other citric liquid.
Step 2: Put lid of processor on and put entire unit in dishwasher. Turn on power scrub cycle.
The dishwashing cycle will help the citric acid to activate the poochy.
Step 3: Use skillz to wriggle the bowl off the processor. Empty out poochy remains.
Congratulations! YOU'VE GOT SKILLZ!
Jun 08, 2009 | KitchenAid KFP600 Ultra Power 11 Cups Food...
I need a manual for a Kitchenaid Food Processor Model #KFP600WH
The Kitchenaid website doesn't recognize the model number you gave. Could it possibly be KFP760? If so, then here's a link to the free downloadable manual.
http://www.kitchenaid.com/assets/pdfs/product/ZUSECARE/KFPW760OB_Use%20and%20Care.pdf
Dec 02, 2008 | KitchenAid KFP670 Ultra Power Food...
I have a cusinart pro classic, went to use it yesterday, filled it and turned in on, got nothing. i tried a different plug and still nothing. it is not even making a sound.
It usually goes something like this, with minor variations depending on model number:
1. Remove the work bowl completely from the base
2. Plug the food processor in and turn it on
3. Use a pen to depress the dark grey/black button on the base – if it spins, proceed
4. Put the work bowl on the base with the handle facing the front of the food processor – slide the work bowl until it locks - the white tabs show in the openings on the bottom of either side of the workbowl
5. Place the lid on the workbowl with the tab slightly left of the center of the workbowl handle – slide the lid counterclockwise until it won’t slide any more
6. Place the pusher sleeve in the feeder tube of the lid with the lock facing the front of the food processor (may vary depending on model)
7. Slide the lock to the right into the locked position
The food processor should now work
-Tha Mp3 Doctor
Oct 19, 2008 | Cuisinart DLC-10S Pro Classic Food...
Lid of food processor
i am also having the same problem. it happened as soon as i got done putting in some parmesan and grated it. never happened before and i've got a few cups of parmesan cheese just sorta wasting away inside the processor. very tempted to break the damn thing open and just buy a new processor from a different company.
Dec 01, 2007 | KitchenAid KFP670 Ultra Power Food...
Food Processors Logo
2,616 people viewed this question
Top KitchenAid Food Processors Experts
ThaMp3Doctor
ThaMp3Doctor
Zhareese
john h
Are you a KitchenAid Food Processor Expert? Answer questions, earn points and help others
