SOURCE: 1998 Nissian Altima Not starting
Nothing by either party was said about the starter. The battery and wires can all be in great shape, and if they are and the owner hears a clicking noise when trying to start it its a pretty good bet they may have a starter that's locked up.
One good 'ole trick on those starters. If you can reach the starter, a couple of sharp rapes with a hammer will have it starting again, then you know it time to replace the starter.
Bill
SOURCE: nissan altima 2005 noise from engine
i had the same issue had the alternator replaced and their is no longer a noise.
SOURCE: Nissan Altima not starting(sometimes)
change your crank angle sensor and it should fix your problem
SOURCE: My 2005 nissan altima will not start. I try to
Hello and thank you for using FixYa!
If you have a Service Engine Soon light on, then most likely you need a cam or crank sensor. Those are the most common. I would have the car checked to verify.
Thanks Jay!
SOURCE: clicking noise when try to start 2005 altima
sounds like you need to check the connections from the battery to the starting motor and you may also need to check the connections to the solinoid motor as well
