Question about Casio Computers & Internet
No sound from left speaker in casio wk-210 - Casio Computers & Internet
5 Suggested Answers
ROD GANDY
  • 1602 Answers
SOURCE: only static comes out of speakers on my wk-3500
IT IS POSSIBLE THE SPEAKER SHORTED OUT BUT I HAVE A PROBLEM WITH THE EAR PHONE AND SPEAKER BEING BLOWING OUT TOGETHER, BECAUSE WHEN YOU PLUG IN THE EAR PHONE THE DEVICE SWITCHS THE SPEAKER OFF AND THE EAR PHONE WORK, YOU CANNOT HAVE BOTH WORKING AT THE SAME TIME UNLESS YOU HAS SOMEONE GO IN THE SYSTEM AND MAKE THAT ADJUSTMENT FOR YOU, THERE HAS TO BE A SHORTED WIRE SOMEWHERE, THE SPEAKER THEM SELF MAY HAVE A FUSE LINK SOME WHERE ELSE IN THE SYSTEM.
I WOULD TRY AND FIND THE SCHEMATICS FOR THE KB, SPEAKERS, MAYBE FRIED ON OF THE IC CHIPS ON THE BOARD. IF YOU FILL CONFORTABLE TAKING THING APART THAN TAKE IT APART AND SMELL AROUND THE CIRCUITS AND YOU WILL FIND WHERE THE SERGE HAPPENED, THAT SMELL LIKE MELTING PLASTIC.
RODGANDYSR567
Posted on Mar 05, 2009
Fred Yearian
  • 5603 Answers
SOURCE: My WK- 3700 Casio keyboard is malfunctioning.
One portion of the key scanning matrix has gone bad. First thing is to clean the contacts with 99% isoprophyl alcohol. These USUALLY consist of traces on a circuit board that conductive rubber "pills" under silicone rubber domes are pressed down. Each note usually has two contacts, one closes before the other. This creates "velocity" measurement for the key. IF ONE of the contacts for a key doesn't work, the velocity can detect that the note has actuated, but no release occurs.
This would be on the "STROBE" line for either the first or second contact for THE OCTAVE you have problem with. There are disconnect diodes that prevent sneak paths.
You could have one bad diode, a crack in the circuit board, or a bad connection to the keyswitch board.
Posted on Nov 27, 2009
peeface
peeface
  • 180 Answers
SOURCE: need a casio wk-110 manual
http://support.casio.com/pdf/008/wk_110_01_e.pdf
Posted on Apr 28, 2010
Testimonial: "Talk 'bout fast !! Within minutes of posting the problem, I had the solution. WOW! THANKS SO MUCH. BOBBYRAY"
Lance Hill
  • 1739 Answers
SOURCE: I need a USB cord
Are you referring to the Casio WK-210 Keyboard.?
A User Guide can be found here:
http://support.casio.com/pdf/008/WK210E1A_web.pdf
Beginning of page 59 of the PDF file is a description of how to connect to your computer.
You are to use a commercially available A-B Type USB cable; meaning one end has a Type A connector for connecting to your computer and the other end a Type B connector for connecting to the keyboard.
The USB cable is not provided.
The cable is commonly available and could be purchased from any company that sells computer parts and cables.
Trust this is helpful. Please vote.
Posted on Dec 27, 2010
sottirtkote
  • 25 Answers
SOURCE: I do not know where
Here are some great source where will will get any kinds of Gaming Consoles Solution
» Sony Playstation 3 (PS3) Console
» Microsoft Xbox 360 Console
» Nintendo Wii Console
» Sony PlayStation Portable (PSP) ...
» Nintendo DS Lite Console
» Sony PlayStation 2 (PS2) Console
Number of vote for this solution:5
Posted on Feb 17, 2011
When I plug in stereo headphones in the casio wk 210, the sound only comes out of one ear. I didn't really care about that before, but now when I connect a line out from the piano to my computer to...
The output of the casio may only be mono, you can buy splitters to create a 2x channel output. Is there any other outputs from the casio other than headphones, usually there are red/white RCA outputs (Phono's) which would be better for connecting to your soundcard.
Hope I was of use to you, good luck.
Aug 04, 2011 | Casio WK-210 PACKAGE 76 Keys Electronic...
Hi, i have a problem with my casio wk 210 keyboard. when i push a key then the note keeps playing and doesn't stop. i have tried turning off the power and turning off reverb and none of them fix the...
It sounds like the sustain is stuck on as if a sustain pedal is active. You don't mention if you have one, however if you MIGHT have one and you have used a Roland pedal, that brand is reverse sensed and would cause note to remain on.
Jun 14, 2011 | Casio WK-210 PACKAGE 76 Keys Electronic...
Re: Casio WK-210. Audacity, Jet Audio and Ctrl Pnl allow me to choose a USB PnP "record from" option, however, no sound is being recorded from the Casio to the PC. What am I doing wrong. Many...
Pat, the USB output on the Casio WK-210 is only capable of sending and receiving MIDI information. It's not sending any digital or analog audio. Audacity is primarily for sound file editing.
In order to use the keyboard to record onto your computer you can connect an audio cable from the 1/8" stereo mini-jack to an input on your computer. Then you can record into Audacity.
Or you can acquire MIDI recording software (ie. Logic, Cubase) and then using the USB output on the keyboard, you can control and record multiple MIDI instruments in those programs.
Feb 23, 2011 | Casio WK-210 PACKAGE 76 Keys Electronic...
I need a USB cord for my Casio WK-210. Does it come with one? If not, where could I buy one?
Dec 27, 2010 | Office Equipment & Supplies
Need a manual for casio wk 110
Why not download it?
http://www.generalmanual.com/Musical-Instruments/Casio-WK-110-Portable-Keyboard.htm
There;s a link on that page.
All you need to do is google the words
casio wk 110 manual
And you find your answer,
Hope that helps you.
Apr 25, 2009 | Casio WK110 Portable Keyboard
Only static comes out of speakers on my wk-3500
RODGANDYSR567
Mar 04, 2009 | Casio WK110 Portable Keyboard
SMF converter for wk-500, Does it exist?
No.
I have a Wk-8000 & a CDP-200R, the later is the same as wk-500 but with 88 weighted hammer keys.
Since wk-500 can play SMF (Midi 0 & 1) format directly from a SD card and there is enough polyphony to play anything, I don't find any real reason to convert SMF to any "Casio Format". Just get a 2GB SD card and put your SMF files in the MUSDAT folder for the SD CARD using your PC/MAC.
Dec 31, 2008 | Casio Lighted Keyboard LK90STADMC
Casio wk 1200 sound cuts out - how do I open it up to fix it?
Excuse Me Im Have Diffuculties Recording My Own Songs Can Anybody Please Teach Me How 2 Record On It?
Mar 17, 2008 | Computers & Internet
Computers & Internet Logo
154 people viewed this question
Top Casio Computers & Internet Experts
Ekse
John Tripp
John Tripp
Sumeet Sodhi
Are you a Casio Computer and Internet Expert? Answer questions, earn points and help others
