Question about Minolta Office Equipment & Supplies
My konika minolta c280 does not display scanning to usb button, how to set usb function
Posted by raman dharmraj... on
emad
    Habit-Forming:
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 7 Answers
Because the hard disk not installed u can sure from system 2 HDD
Posted on Jan 09, 2018
  • emad Jan 09, 2018
    or u can sure from press key utility /counter and press 1 5 6 u see four square chose the configuration square and chose the tray & press the start Patton the machine print paper in this paper u can see if the HDD installed or no.
Norman J Weimar Jr
  • Minolta Master
  • 6,960 Answers
5 Related Answers
Anonymous
  • 84 Answers
SOURCE: I want cd for instale KONCA MINOLTA PAGEPRO 1300W (driver)
Try this driver (choose the operation system)
http://crm01.konicaminolta.eu/openmind/technic/kmpsdwl.nsf/psearch?OpenForm&ch=PRI&dist=BPE&ui=en&dg=sw&prod=PagePro%201300W&dsg=&os=&lang=&ml=0&rid=41256849005CE173&sub=Printer%20Driver&pcat=B%2FW%20Printer&pcc=1
don't forget to vote!!!
Posted on Jan 19, 2008
Bubbabear64
Tim Babcock
  • 2794 Answers
SOURCE: konika minolta
CDC##  Appears to be trouble related to security.
The only solution is to contact Konica Minolta to find out what needs to be done to resolve the problem.
That is only solution the service manual has provided.
Posted on Nov 07, 2008
Anonymous
  • 162 Answers
SOURCE: lost connexion to windows server
Check if it's online in the Server, o a scan and print. The check the sharing status - is it shared ?
Posted on Nov 21, 2008
mochicas
  • 26 Answers
SOURCE: Driver utility of Konika Minolta Bizhub 162
Use the bizhub 180 same family
driver
Posted on Feb 21, 2009
trainjunkie
  • 35 Answers
SOURCE: dimage dual scan 4
Use VueScan instead of the Minolta software. A free trial is available so you can test it before you commit to buying it. Available for Windows Vista.
http://www.hamrick.com
Posted on Aug 16, 2009
Solve check printer mode with usb printer.A4 paper error From konika minolta bizhub215
Your paper size is different from computer setting
go to device and printer click your bizhub 215 click printer preference click back click paper size ser A4 then ok and print
A4 paper setting of bypass with usb & Tray1 From Konika minolta bizhub215
Go to the control panel under paper select bypass tray set to A4 or 81/2x11 select weight and the go to computer select bypass tray and paper weight
How to set up scan to pc on bizhub c280
GO to below web site down load the free scan manual for your model. Self Help Product Support Konica Minolta Business Solutions Inc
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Konika minolta 1690mf displaying CAUTION machine trouble service call(0500)
hold down the stop button and power on, if the code come back get a new fuser unit
How can i reset my konika minolta 162 to function well which is writing service call and a code C0500
C500 fusing unit malfunction.Look at a liitle holle on the right side on display.Press the microswitch and wait will apeire * and press 3 and press trouble reset.
1helpful
Konika minolta di1611 error xodes
You must be change the developer and the opc drum and drum cleaning blade.
Konika minolta pagepro 1380 printer
try out the vista driver>it may be functional for win7
2helpful
Konika Minolta 2400W can not connect. Clearly Windows XP sees it, and the driver is installed etc. When I plug or unplug the USB cable, Windows plug 'n play notices the difference. And the USB cable works...
Everytime you disconnect and reconnect the USB cable to a different port, unfortunately, Windows creates a new and distinct copy of the printer. You can see this by looking at the Windows Printers folder. The solution is when you change around USB ports, right click on the printer icon that is actually the active one (the other copies will be grayed out) and Set to Default. Then you can delete the other invalid copies. Then in the Minolta status software, go to the Display menu and Select Printer to change which printer is monitored to the correct copy. It's very stupid that Windows Plug n' play does this, but it does. So avoid change around USB ports on your Konika Minolta printer.
Konika minolta bizhub scan button is not selecting
which model you have?
there are two types of scan available push scan and pull scan
Top Minolta Office Equipment & Supplies Experts
Daniel Blask
Daniel Blask
Mehandi Husain ...
George Mclaughlin
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
