SOURCE: can not get thread tension on hobby 1200 grand
Adjusted the dial to the right until the stitches we better.
SOURCE: thread breaking on mega quilter
Upper thread breaks
needle may be in backwards
Raise the needle bar to the highest point, then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine
round needle--the groove in the needle should face away from the shaft.
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
upper tension may be to tight try 3 to 5
the needle may be bent or damaged
thread may be hanging up in bobbin case--check area for loose threads or lint
SOURCE: How do I raise and lower the feed Dogs on the PFAFF hobby 1200 Grand quilter
According to the following web site, the feed dogs do not drop on this machine, Instead, there is a plate that covers the feed dogs:
Fluffy Sheep Quilting Do you have one of these Do you like it
Also thought this was interesting:
Oiling the PFAFF Grand Quilter 1200 Bernina Sewing Center Tampa
SOURCE: Pfaff grand quilter 1200 - how do I adjust the timing of the machine? Thanks, mike and mum!
Search for "sewing machine timing."
