SOURCE: Projected image on Emerson SmartSet faulty.
You will have to call Emerson customer support for this type of repair. What happened is the display circuits have been damaged in the fall. You can call the customer support at this telephone number 1-800-898-9020 between the hours of 7am-5pm CT. Give them the make and model number of your Clock/Radio. Ask them where you can find a authorized service center in your area. Try to get a telephone number. Call the service center and ask them if they do out of warranty repairs. If they do tell them the problem you have had with the Clock/Radio. Ask them to give you a estimate of the cost including shipping and handling before having it repaired. This way you can judge whether it is worth it to repair the Clock/Radio or replace it. I hope this information help you with your problem.
SOURCE: Looking for a battery for
Sorry it took so long to answer your question on where to purchase the CR2430 lithium battery.[http://www.google.com/search?q=cr2430+lithium&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a]Copy this web link and paste it in the address bar of you web browser. it will take you to a google web page full of places to purchase the CR2430 lithium battery used in your Clock/Radio. I hope this information solves your problem. Thank you for using FixYa and have a nice day.
SOURCE: Directions for Resetting the Daylight
Unfortunately, you can't reset the firmware of the clock for those built before Jan 2006; you can work-around the issue. You will need to change time zones for the few weeks between the current daylight savings start and end dates and the ones that were built into the clock. For details see: http://www.emersonradio.com/dst.htm ; click on the link for Group 1.
If the unit was built before Jan 2006 (the serial number will start with a value less than 6), switch the time zone to the next one further east on the second Sunday of March, then set it back to your correct time zone on the first Sunday of April. Repeat this on the last Sunday of October and the first Sunday of November. (If you are in the Eastern time zone (zone 2), set the switch to zone 1.)
If the unit was built between Jan 2006 and July 2006 (serial numbers that start 601 to 606), then you can change the start and end dates for DST. See: http://www.emersonradio.com/dst.htm then choose the Group 2 link. Press and hold the Alarm 1 button then press the Month/Date or Calendar button. After three seconds the unit will display the start date for daylight savings. Press and hold the Alarm 1 and Month/Date or Calendar buttons. When the display is flashng (within 5 seconds from the press and hold step), press the Down or Set button (depending on the SmartSet mode) three times until the display reads 3 and F2 (alternating with the date of that Sunday).
For the end date, press and hold Alarm 2 then press the Month/Date or Calendar button. Then press and hold Alarm 1 and the Month/Date or Calendar button. Again within 5 seconds, press the Up button or Set until the display shows 11 and F.
If the display stops flashing, repeat and set the new dates faster.
You'll have to repeat this is the battery is removed or replaced.
I hope this helps.
Directions for Resetting the Daylight Savings Time (DST) Start & End Dates on the Emerson Research Smartset Dual Alarm Clock Radio (cks5055s):
One thing to note, if you ever have to change the lithium backup battery for the Smartset clocks, it will revert back to it's factory defaults and you'll have to go through his all over again.
And this conclude's Search Marketing Guru's public service announcement. :) We'll be back with relevant online marketing posts with our next posting!
