SOURCE: Blank Screen and faulty shutter blades
I found out the hard way that you should never use alkaline batteries in a Digital Camera. I thought my camera had a fundamental flaw (power kept going off whenever I tried to take a photo or record a video and the shutter blades half closed) even though it was only 2 months old. I nearly wrote it off but all along the problem was that I was using alkaline batteries, which incidentally were enclosed with the camera in the box!! Once I switched to NiMH (Nickel) batteries the camera worked fine and the fault completely vanished! These NiMH batteries are avaiable in most electrical shops i.e currys/comet in the UK. They must be charged before use. They are more expensive than alkaline batteries (£8-£9 for 4) but as they are rechargable they last a long time.
SOURCE: CAMERA and VIDEO mode dead
This sounds like it might be a defective CCD imager. If so, Sony should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following link for more info:
http://camerarepair.blogspot.com/2007/11/sony-konica-minolta-cameras.html
Applicable cameras include:
Cyber-shot DSC-F717, F88, P10, M1, P12, P2, P31, P32, P51, P52, P7, P71, P72, P8, P92, T1, T11, T3, T33, U10, U20, U30, U40, U50, U60, V1
CD Mavica MVC-CD250, CD400, CD500, and FD Mavica MVC-FD100, FD200
CCD Failure !
Lucky u can get it repaired Free just call Sony in ur region see link
http://esupport.sony.com/US/perl/news-item.pl?mdl=DSCT1&news_id=161
SOURCE: Camera turns on fine. I could view picture and
Your have a "Display" button that toggles thru different display modes .. one of the modes turns off the LCD backlight .. that useful if you are in bright light and dont need the backlight .. you have a very nice "transflective" display that works great in bright light without the backlight ... you can get more shots with the backlight turned off on each battery charge .(about 25% more) .
so each time you operate the display mode button you will get a different display .. one shows a hystogram .. one turns off the backlight and one puts the camera in a normal mode ..
if everything is working right then even with the backlight turned off you should be able to go outside or any brightly lighted area and see the picture on the screen ..
SOURCE: Constant Charging Flash HP Photosmart R927 digital camera
First I'd try turning the flash off, a manual option on nearly all camera's. Take a couple of photo's without flash, and turn the camera off and on a couple of times then turn the flash back on to auto.
If that doesn't resolve the problem, I suggest going to the HP website, follow links to support and/or downloads and see if there's a firmware upgrade for your camera.
