Hi Jo.
this is all i can find at mo.
Change the phone ringtone and notification sound on your Alcatel ...
devicehelp.boostmobile.com/.../ONETOUCH.../Change_the_phone_ringtone_and_notifi...
if this does not work then go to this link might help you out some more.
How do change ring and text tones on my Pixi Alcatel One Touch Google...
SOURCE: I would like to change
I found the answer!! Go to Menu>Settings>Profiles, then go to Options>Edit. Push the right side of the square (that you use to navigate the menus) so that you're working with New Messages, not Incoming Call. Go down to Message Alert Tone, then go to Options>Change>Use Effect Tone. If you were trying to use an .mmf that you downloaded, or any of the preloaded ones that can be used as incoming call ringtones, you'd go to Use My Alert Tone here. There are 4 tones under Use Effect Tone, and you can play them and choose one, just like you do to play and choose your ringtone.
SOURCE: assign different ring tones for email or text mess.
You can not do that as far as I am concerned. It's all the same sound for any type of message.
SOURCE: I want to change the ring when i get a text message i need with changing it
Click this link:
http://www.pantechusa.com/download/matrix/Matrix_UserGuide_En.pdf
This is the guide for your phone. To change the tone for messages simply go to Menu - My Stuff - Audio. Select folder, select song or sound file, select it for message/SMS tone.
SOURCE: ringtone for incoming text??
Most samsung models dont let you use ringtones as txt alert. Soz.
Follow the instructions herehttps://bestringtonesfree.info/name-ring...
You can go to our website to change the ringtone at https://ringtonescloud.com/
You can visit https://toquedecelular.com/ to get help.
