Hi, take a look at this video. You problem is probably a drain valve that is not closing completely. It could be due to debris getting stuck in it or the valve itself is failing. This video will help you figure out what it is and how to fix it.
Hi Philip.
this is all i could find.
It can get stuck on this cycle indefinitely and it's called siphoning. Siphoning occurswhen the end of the drain hose is lower than the level of the water inside the washing machine. The diagram shows a correctly plumbed in washer where the end of thedrain hose is higher than the level of water in the drum.12 Jul 2013
Washing machine fills and drains at same time - White goods help and ...
https://www.whitegoodshelp.co.uk/washing-machine-fills-and-drains-at-same-time/
or this link.
How To Fix Washing Machine That Fills And Drains At The Same Time
or read up more at this link.
washing machine drains water while in wash mode Google Search
SOURCE: aeg 72630 update will not rinse during rinse cycle
If the drain lines were plugged, there may have been enough pressure on the pump to fault out. Make sure the sewer line is completely open, as well as the lines at the pump.
SOURCE: Bosch WFF1201 Washing Machine, wont drain
To access the pump filter, remove lower plastic panel at front of washer, there you will see the filter, unscrew filter cover anti clockwise, remove and clean filter.
You will probably find that whatever was causing the clicking noise is something in the filter.
If you can't see anything in it , then have a look inside the pump housing before you replace filter.
Plz rate my solution .
Thanks.
SOURCE: Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
SOURCE: the washer will not drain or spin
more than likely the pump needs replacing, first of all remove the outlet drain hose from the the place it discharges and lower it into a bucket,this should allow it to syphon away,you may need to empyt the bucket a few times once the machine is empty you should be able to put it on its spin cycle once it has spun locate and remove the filter to remove any objects or lint, fill machine with warm water and try to drain and spin via the programme,if this do not work fit a new pump
SOURCE: washing machine not spinning or draining water
its your drain pump if you can hear it humming but no water is draining it is blocked or jammed by a foriegn object (most probably a 20 cent coin or bobby pin/s), if you can hear it working as normal but still no water it may have a blockage sumwhere along the drain pipe either that or the impellor has snapped off the shaft and is ratteling around and not actually turning, and with the spin that is directly related to yor drain pump issue as the washer will not even attempt to spin if water remains in the tub, incredibly easy to do hit me back if you want detailed instructions
