SOURCE: prolonged washer cycle time
Hi! I'm not familiar with this model, but it sounds to me like there is not a problem! If you set the delay time to 0H, switch off the unit at the main switch, then switch back on. If there is still a 2H displayed, it means that the PROGRAM that you have selected will take 2hours! This is fairly common for the Bosch units on the 50 - 65degC cycles...some models have a "reduced washing time" button - it looks similar to the "delay" symbol, but once pressed, it reduces the washing time by almost half (cuts on rinse cycles) If your model does not have a reduced time button, select a shorter cycle (35/40/50eco), and see if the time is less. Remember that the latest dishwashers are engineered to be more energy efficient and water wise, so they had to lengthen the wash cycles in order to get good wash results! Hope this helps! C.
SOURCE: control lock light
someone has enable the child lock feature. One of the buttons should say hold 3 secs for control lock under its normal function description. Hope this helps
SOURCE: Whirlpool duet front load washer flashes F35 shortly after start
Sud= The unit has sensed there is too many suds in the unit it will
flush and pump out for 5 min and restart on its own..This is caused by
too much soap use..
From the book :
SUD Code=
If too much detergent was used:
—Run the unit through a Rinse/Spin cycle.
—Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
SOURCE: I have a GE WBVH6240HWW Front load washer. I
i would try to clean the trap out at the bottom, there is a panel on the bottom take that off and clean out the trap, it looks like a turn dial, something like that has happend to me, it cant hurt to try
SOURCE: Help with Model #GHW9400SU0 Whirlpool Duet Front Load Washer
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the
CONTROL LOCKED status light turns off.
