SOURCE: Whirlpool Control Panel Repair
model # MH6150XLQ
LOST POWER. I CHECKED WALL RECEPTACLE. IT'S GOT POWER.
MICROWAVE IS DEAD. NO LIGHT..........NOTHING.
WHAT'S HAPPENED?
SOURCE: How do I remove the selector knob on washer
The main selector control know spins off by turning the selector inner knob counterclockwise. The outer ring will then pull off. The other knobs are held on with friction and should just pull off.
The best way to get behind the front panel is by removing the top panel of the machine. There should be 2 gray/solver tabs at the back of the machine near the top if you remove the 2/4 screws from the top then the whole top panel will slide forward then lift off.
Be sure to unplug the machine first.
SOURCE: GE washer model WBSE3120B2WW has
I have a very simular problem. It started by running a cycle without me even being in the room. The only way I could stop it from filling and running through a cycle was to unplug it. I left it unplugged for about week & 1/2 - 2 weeks and when I plugged it back in, it worked just fine. It has started running by itself again but now I push the start button and nothing happens. Any solutions?
SOURCE: GE model JKP13GOP2BG control panel faulty ( F1 code)
Often times when someone makes an attempt to "repair" a control, it does not hold up. Replace the entire control. Don't waste your time. You will also get a year warranty on a replacement control.
