SOURCE: Built-in DVD player
Are you trying to play DVD's you've made or copied yourself or new one's you buy from an actual distributor? Because sometimes self-ripped Cd's & DVD's won't play on a LOT of DVD players. Otherwise it's bad DVD player and you should go get it swapped out if it's not too late.
SOURCE: 26 inch insignia dvd/tv combo
This is a long shot but, there may be a reset button on the back of the tv if not try unplugging it over night.
Good-luck
Rob
SOURCE: connecting COX DVR and Phillips DVD to Vizio HD TV
we connected the cable box to the coax connector while our philips dvd went into the HDMI1 connector, and we got both working fine and dandy
SOURCE: 26 inch Proscan with no manual
You can find the the manual in pdf form on the PROSCAN website. look under support for manuals and find the one you need and down load it for your use. The website is . www.oncorpus.com You can also call the PROSCAN customer support at this telephone number.1-888-977-6722. I hope this has helped you with your problem.
SOURCE: i need help connecting my vizio tv to my dvd
how hard could it be? Oooo your a total air head huh? its as simple as 1, 2, 3. plug in your power to your dvd player and the red goes to the red the yellow to the yello and the white to the white.. IDIOT!!!
