Cannot see menu lines above timer feature or below the red toolbox setup icon
SOURCE: menu format
simple just change ur themes .....other than circle shine
Posted on Mar 06, 2008
SOURCE: Sony Trinitron Color TV KV-35V65 - No Picture, red light stand/by timer flashing
A reset won't fix this. The standby light should be blinking a repeated count with a 3 second pause inbetween. Post that count here. That will indicate the circuit/condition that is preventing the set from turning on.
Thanks,
Dan
Posted on Jul 18, 2008
SOURCE: My PS3 turns on and plays the beginning music and displays the
I had this same problem today. The solution was to reload the file format. To get to the screen that allows this, turn on the machine and remove any discs. Then press and hold the on/off button until it beeps twice. This puts the machine in sleep mode (red light on front). Now press and hold the on/off button until it beeps three times. Then a menu pops up that gives you several options. The one that worked for me was to reset the file format. It popped up and told me that the file format was bad and it was being fixed. It did this twice and then it started working again. Good luck.
Posted on Dec 30, 2008
SOURCE: i have a thin red line vertically on the left side
You have a defective panel. The only fix is to replace the panel. This would not be cost effective. Cheaper to buy a new TV.
Posted on Apr 26, 2011
SOURCE: Thin red line across screen two inches for the
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hope this will help out.....
Posted on May 12, 2011
