Question about Acer Televison & Video
I have a Acer Aspier one, I have lost my charger wire, I can't charge my laptop.
Can I buy a charger from you?
Posted by Dorothy Gullo on
5 Related Answers
Anonymous
  • 458 Answers
SOURCE: acer laptop power problem
Does not switch on from mains.?????????????
PLEASE EXPLAIN..........
Is the laptop lights not coming on when you plug it in? If not refer to the following.
Are you sure that your power plug has not broken loose. You will have to take the laptop apart to find this out. Sometimes the solder joint will come loose. Do not take this laptop apart unless you know what you are doing. The manual can give you step by step directions sometimes. It is not easy to take it apart without breaking the little things. If you do take it apart, take pictures of every step and take notes and even draw picture so you will know where everything goes. You can touch the plug where it is soldered and re-solder the plug. Please be careful. This takes someone with good solder skills to do.
Posted on May 30, 2008
Anonymous
  • 94 Answers
SOURCE: How get for Internal from Acer Aspier SH85-524B8
try www.global acer.com/support/downloads.htm they have acer computer software and utilities there
Posted on Oct 26, 2008
Adaptation41
  • 48 Answers
SOURCE: how to remove bios password
Usually on any laptop generally you have to disconnect (remove) the cmos battery inside the laptop inside. It can be a pain taking apart the laptop but that's the only way. Sometimes it is easier on newer desktops because they have a reset password jumper but on laptops you'll take the cmos (coin battery) out, wait 5 minutes and then re-insert. Good luck!!!
Please rate and comment!!!
Posted on Dec 23, 2010
Geekman
Chris Hingee
  • 32281 Answers
SOURCE: My Acer Aspire 4530 Laptop
Whenyou connect the power adapter into the laptop, does the power LED light up? Ifnot then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Posted on Feb 25, 2011
hillardx
Andrew
  • 134 Answers
SOURCE: charger are not working very
Take it back the battery sounds DOA theres no need to take the chance if you only had it cuple days.
best of luck
Posted on Mar 06, 2011
Acer aspire fuse
Laptops don't have fuses in them. All the protection is built into the battery and the charger. The most common problem with them is the charging cable gets too much stress put on it and it either breaks the wires in the cable or damages the plug in the computer. You can take the charger into a radio shack store and have them test it with a meter, you can take the laptop into a store like best buy and see if they have a charger for it and tell them you want to be sure it works before you but it and if it does not then you can be pretty sure the issue is with the charging jack. Or you can just order another charger online and take a chance.
May 27, 2015 | Acer Computers & Internet
My acer aspire 7520-5185 will not turn on
Hello. There is a hardware failure with the laptop not the AC charger. AC chargers have some range of protections of their own. If the power requirements of the laptop are bigger then what the charger can handle, the charger will turn off. Also other parameters can bring the charger offline. In your case, you have a problem with a small chip, the battery charge controller unit, witch regulates the amount of current required to propperly charge the battery. When this thing fails, the charging requirements for the battery are reported rong and the AC charger is forced to give more power then necesary. This results in disconnection of the AC charger ( an internal fail safe of the
AC charger) and the laptop to swich back to battery power. When the laptop is turned off, it can charge the battery because the power requirements are low, having all processor, main board, hard disk etc turned off. Therefore the AC charger can handle the load. However you will need to have it checked by a service center as it is a hardware fault. Both AC charger and laptop needs that check.
The charge controll circuit needs to be replaced probably. It will be a somewhat expensive repair. Don't buy any other battery untill you have the laptop checked.
Acer Aspire 7520
Jan 13, 2013 | Acer Aspire 7520-5185 Laptop
My zg5 laptop battery will not power my laptop.battery is new. fully charged.
Hi John,
For the sake of clarity: the battery which will not charge/power your Acer Aspire One Netbook is the original battery that came with the Acer, is this correct?
Assuming that the answer is Yes then replacement with a NON Acer, universal battery is the only solution.
Reputable internet shops, such as Amazon, have these at around $50...
DANGER; Due to the recall of thousands of Acer (HP and others) batteries with a possible fire hazard please dispose of promptly and properly.
Best Buy has a Recycle program:
http://www.bestbuy.com/site/Global-Promotions/Recycle-FAQs/pcmcat174700050009.c?id=pcmcat174700050009
If this link does not work please Google Best Buy Recycle
Thanks!
Jimm
Nov 20, 2012 | Acer Aspire One Netbook 8.9" Notebook
I have lost my lead to my acer laptop aspire5100 series model number BL51 19v .474Acan you help.I am a mature age person thanking you Pat
There are two solutions to this problem, Pat.
One is to buy the correct AC adapter (Charger) for the laptop.
Two is to buy an aftermarket AC adapter that will work for your laptop, but will also work for many other laptops.
1) http://www.usbphoneworld.com/acer-adapter-19342-65w-lc-adt01-aspire-5520-ac-acer-aspire-5100-ac-adapter.html?CAWELAID=950033775
The above is from a quick search. Your search may be better. Just put Acer Aspire 5100 charger, in your search box.
2) From another quick search,
http://www.atbatt.com/laptop-chargers/b/acer/m/aspire-5100.asp?utm_source=google&utm_medium=ppc&utm_keyword=Acer+Aspire+5100+Charger&utm_content=NAC-X90-22&utm_campaign=google0&gclid=CLeDr7qIlqsCFQ9S7Aodvn_TXA
Would also like to commend you for your intelligence.
Stating the Voltage, 19V, and the Amperage, 4.74A ,is a really intelligent thing to do.
(The charger MUST have 19 Volts for the Voltage. The Amperage (Amp's, or A), can be more)
For additional questions please post in a Comment.
Regards,
joecoolvette
Sep 11, 2011 | Acer Aspire 5100 Notebook
Hi i lost my acer cyrstl eye webcam aspier 6920g how can download plz let me know.
Hi, first click on this link and then download
http://www.acer.ae/ac/en/AE/content/drivers
After download click on notebook and then aspier then choose your model6920 g and then click once again on model and choose operating system.
Best of Luck
Aug 07, 2011 | Acer Aspire 6920 Notebook PC
Charger is plugged in but not charging but can still power the laptop, how can i get the charger to charge the laptop
Same topic on hardwareanalysis.com:
AC adapter not charging Dell laptop battery, but still works?
http://www.hardwareanalysis.com/content/topic/75751/
Source for Acer Aspire 5520 AC Adapter
May 10, 2011 | Acer Aspire 5520-5908 Notebook
Oct 26, 2008 | Computers & Internet
Televison & Video Logo
52 people viewed this question
Top Acer Televison & Video Experts
Marvin
Marvin
Paul Bade
Harrie
Are you an Acer Televison and Video Expert? Answer questions, earn points and help others
