No, the designs on a memory card for the Memory Craft 300e do not work in the MC8000, or vice versa. The designs on memory cards for the MC9500 will work in the MC300e. See http://janome.com/en/learn/software-lessons/transferring-designs/compact-flash-card-mc9700-mc9500-and-mc300e/ for some information. The physical cards appear to be the same. If you have extra space on an existing card, you could put another file onto the card with the appropriate format for the other machine.
The MC300e reads a .JEF file; the older MC8000 reads the .SEW file.
I hope this helps.
SOURCE: downloaded jef files for janome 300E, but card
when you put them on your card, are you making sure they are in the emb file??
SOURCE: looking for online user manual for Janome Memory
You can view and download the instruction manual in PDF format by clicking this link.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this helps. Thanks for using FixYa.
SOURCE: Where is the touchscreen reset button on Janome
There is no reset, just some tests to determine whether you need to replace the LCD Backlight....look HERE
SOURCE: JANOME MEMORY CRAFT 8000 MANUAL
you can download the instruction manual here http://www.blowssewandvac.com/files/janome_inst/
for free, just right click on the manual you need and save link as on your computer and enjoy using Janome Sewing machines.
thanks
SOURCE: format pc card on janome memory craft 300 e
You can just change your memory card only 1GB or less and upload designs through customizer software i think your problem will be solved.
