Question about Rotel Audio Players & Recorders
Probably the EEPROM, the heart and brain of the appliance.
I had the same issue with my AIWA, could not figure out the cause, took it in, tech told me EEPROM is blown.
Not economical to repair.
Posted on Nov 20, 2017
SOURCE: Rotel rx 1050...Not working
If you are not using the 12v trigger between pre-amp and power amp make sure that the trigger switch on the rear of the RB-1070 is set to off
Posted on Feb 12, 2008
SOURCE: onkyo sr606 unable to select speaker setup in the menu screens?
sometimes, the memory of the receiver will act abnormally.. what you need to do is return the unit back to factory settings. To do that, press and hold vcr/dvr button and while holding it, press the standby/on button. You will see the word clear. It would reactivate your settings. ^_^
Posted on Dec 16, 2008
Seems that you hav checked and set up rightly and the fault seems to be with the main amplifier drivers. Remove the left and right speakers and test, if these are OK then the fault can be with the outputs if there is no output even with a normal aux input .Take consensus to confirm.
Posted on Nov 08, 2011
SOURCE: Rotel Receiver RSX-1067
Rotel RSX 1067 is a good and powerful unit. But as stated over time heat and vibration will cause issues in these big A/V receivers.
I have repaired many, and for the most part it is solder connections on the power supply board feed-throughs and such. Loss of voltages to the digital board, or blown outputs caused by improper speaker wiring and or loads. All of the above is repairable but only with a very knowledgeable and person used to repairing these units. It is not for the DIY weekend warrior.
Posted on Feb 14, 2016
