I installed a thermostat today and it connected to my total connect fine. I then installed a second thermostat and when I try and add it to my account and register it I get an Unexpected error.
Posted by Meg Seville on
Neil Hadrich
    Habit-Forming:
    New Friend:
  • 7 Answers
Sounds like wiring issues. If not the obvious which would be a faulty thermostat. Two thermostats in operation on one heating unit have to be wired in a way that one will not override or interrupt the other.
Posted on Nov 20, 2017
5 Related Answers
otacon
Damen Wong
  • 1950 Answers
SOURCE: Can not get the second handset to register to the base
After you got the no connection message after trying to register the second handset...did you try to register it again?
Posted on Jan 01, 2008
Anonymous
SOURCE: Error message when trying to send pictures
i work at a cell phone support group called ict, we get this problem all the time with the lg phones. the problem is with the carrier select in the programming. have your phone reprogrammed...you will need to contact your service provider for you lock code, but you can usually get into the programming screen by dialing ##program# or ##data# from the main screen of the phone (you do not need to dial this number or hit ok once putting in the last #, it will automatically pop up if you are doing the right code. again, you will need your lock code from your service provider/carrier. once you have that go into the programming and go to carrier, high lite which ever carrier you are with, hit ok and the phone will shut itself off, turn itself back on and you should be able to send your picture without further problems..
...if it then asks you for a pass, call your service provider, they also need to give that to you and if it says error 256 after that, then call your service provider because the url needs to be changed...
hope this long winded post helps you guys.
Posted on Feb 05, 2008
Anonymous
error 256 is when youve tried too many times with the same p/w.. call in to TECHS and have them reset the account and give you the proper p/w...
i dont do this for a living.... whatchu talkin bout?
Posted on May 26, 2008
MrScary66613
Travis Humphries
  • 1990 Answers
Are you with ATT? I got notified Yesterday by ATT that they are having Widespread Multimedia Problems at this Time. Should be fixed by Next Week.
Posted on Jan 04, 2009
anasmaq
Anas Al-Mustafa
  • 100 Answers
SOURCE: my phone says error in connection
if it does it all the time, then you have a problem with the internal antenna or RF section of the phone.
if its occasional, then its normal, cuz when the network is busy and specially with crapy service providers where they have limited simultanious calls, then this error will occor more frequently.
Posted on Jan 08, 2009
Unable to access my Netflix account on TV
Is it still not working? If it was working fine before, it's probably a short-term outage. If Netflix is the ONLY service that is not working, then connect to the Netflix website first, then your online Netflix account second. If those both work, contact "help" from your Netflix account.
Aug 25, 2014 | Dynex 32 in. LCD Flat-Panel HDTV
Please install1571 to my account today ????
Edgar, We don't sell, we don't add, we don't install. We only try to answer (most technical) questions. If one of our volunteers knows something about the problem.
Sorry, but please goto the site your account is connected to.
Jul 14, 2014 | Computers & Internet
I cant connect facebook in mozilla
There can be several possibilities... if it shows certificate expired. look at the date you entered it might be too old... else try to reinstall the firefox. There may be you have installed a add-on or a toolbar that can access the facebook accounts. try to disable it and try again to log in...
Sep 16, 2012 | Facebook Social Network
I have a red and a white wire only. I am installing a honeywell thermastat rth111. The heater is an electric air forced one. Where do I connect the wires?
These are not enough for you to install this thermostat properly. You could try hooking red to R and white to W2/E, but an electric furnace requires 4 wires for modern thermostats to run properly. If there are more wires in the line then it's a fairly easy task for a technician to add proper connections in, if not a new thermostat wire will need to be put in place.
Sep 25, 2011 | Honeywell Programmable Thermostat Heater
I have a 4GB Craig MP4 player and earlier today it was working perfectly fine. It turned off automatically and later I went to turn it back on to listen to it and it won't turn on or charge when connected...
Quite often there is a fault with USB charging. Do two things to confirm its not totally broken. First try another USB charger. Second and better- charge from a power outlet at home.
kc
Mar 09, 2011 | Audio Players & Recorders
Ricoh Afficio 250 code SC900
If changing the total counter the fault does not disappear, try pressing . (point) and # for more than 10 seconds. this reset and reload the software.
Jan 03, 2009 | Ricoh Aficio 450 Copier
Baseboard electric heater installed properly, yet won't work.
DID YOU CONNECT TO TH SAME END YOU TOOK OUT WHEN PAINTING WE ARE DOWN TO THE CONNECTION @ THE HEATER MAKE SURE THE OTHER END OF TH ELEMENT IS CLOSED WITH WIRE NUTS AND TIGHT , LIKE I SAID WE ARE DOWN TO THE HEATER CONNECTIONS SO LOOK THERE
Nov 22, 2008 | Fahrenheat Electric Convector Baseboard...
Lost network connection
ok..try to recycle the power for the network modem and router..then turn on the router first, let it stabilize, then turn the modem back on.
Oct 22, 2008 | Linksys Computers & Internet
I have a LP gas log heater, the thermostat is in the living room and I would like to shut this room off this winter. Is it possible to add a second thermostat elsewhere in the house so this can be done?
Yes. If the thermostat is connected with electrical wires you can buy some wire and move the thermostat or add a second thermostat. Just be aware that dual thermostats can cause people to forget that they have to shut both of them off to stop the heater.
Jul 22, 2008 | Heating & Cooling
Add printer to network (Lexmark Z33) useing add printer wizard I tried to add a printer. You are about to connect to a printer, which will automatically install a print driver on your machine .then I...
Are you connecting this by sharing it from a computer connected to the printer thru a local connection? If so, be sure it has the driver loaded for the operating system you are using on the other computer.
Jun 13, 2008 | Lexmark Z33 InkJet Printer
Computers & Internet Logo
Ekse
Marvin
Marvin
