SOURCE: samsung ht-z310 home cinema no sound rear speakers
I seen the same thing when I first opened mine except my "center" speaker wan't working. It had to do with the "Mode" it was in. The Mode button at the botoom of the remote changes the speaker configuration.
There is also an option in the setup that allows you to turn on/off speakers for the system, all of mine were either Present or Small which enables them to work.
SOURCE: panasonic BT100 & sh-fx67 kit surround sound not working
make sure you have speakers A and B on, sometimes that is the problem
SOURCE: Connecting rear Wireless Speakers on Panasonic Home Theatre Kit
Hi
Just push and hold the fast forward button on your receiver and push the button number 3 on your remote simultanously
your unit cames in pairing mode a P appear in the display
after, goes to your wireless receiver and push the reset button on the back
normally after that the unit must connect with your receiver
SOURCE: just connected the SWA-4000 wireless
Actually the SWA-4000 IS compatible with the htz-310t. I'm using the htz-310 system with an SWA-4000 and it works perfectly fine. under the list of compatible systems with the SWA-4000 you'll see the htz-310. so i don't know where the other answerer is getting his facts.
once you press the nubmers on the remote, 0, 1, 3 5 or whatever the numbers are. turn the system on with the on button on the system not of the remote.
if the blue led is on on the swa-4000 then it's communication, there's a link.
if you do a sound test it will not send the static to the rear speakers, at least it doesn't for me. however there IS sound ouf of those speakers. so i know they work.
SOURCE: Hi there I have an LG
Free PDF Manual at the link below should answer your question.
http://www.lg.com/au/tv-audio-video/home-theatre-systems/LG-HT905TAW.jsp
