SOURCE: neff b1421 single oven
my oven is not reaching the required temprature what could the cause be please
SOURCE: dacor single oven flashes an F2 error code and won't stop beeping!!!
This is from manufacture service manual:
-F2- Alarm Heating Mode High Temperature
Is activated when the ERC senses a runaway heat condition or when the temperature exceeds
“runaway limits”. The ERC will beep until the cancel or another function is selected. If the alarm
repeats the F2 alarm check the oven sensor and wiring after fi rst checking for a stuck relay. If alarm
goes away verify the oven will complete a clean cycle without any type of failure.
Another words the problem with oven sensor or relay board.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
SOURCE: replace fan motor in an electric fan oven
For all Free appliance repair videos visit our VIDEO
TUTORIALS
1, If the fan motor in the back of the oven is going round and
the temperature light is on (normally little red light), but there is no heat
then you will probably need a new oven element, these are generally very easy
to fit and readily available from our website these can be tested with a
electric meter.
To gain access to the NEFF element you will
have to remove the back plate from inside the oven. Once removed you will see
the fan and element, if you
look closely at the element you will
probably see a small hole burnt in it where it has blown. Sometimes however
there is no evidence of a fault but the element
is open circuit ie:
broken inside the element casing, either way it will need replacing. Some
elements will are fixed from inside the oven and some are held in place by nuts
from the rear of the machine.
2, If your NEFF fan
oven is getting warm but takes a very long time to cook or is burning the food
more on one side than the other, then you need to check if your oven fan motor
is working you will
see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then
you need To replace the oven fan motor
is a little more
expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating
and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no
heat and no fan then the chances are that someone has put the oven timer
into AUTO mode,
simply put oven back to MANUAL mode and all should be working again.
Testimonial: "thank you very much very helpful"
SOURCE: Have had 4 Neff oven elements in 2 years.
If you are not fitting genuine
elements, this is probably the reason they are failing so quickly.
You will pay a lot more for the genuine article, but they will last a lot longer.
Also make sure the fan is working o/k, as this can cause premature element failure.
please rate my solution.
Thanks.
