The ovens always heat higher than what I set them to.
Hi there.
this is all i could find.go to this link and see if it helps you.
How to calibrate DCS ovens Google Search
SOURCE: Oven Doesn't Reach Set Temperature
Check the element for burns/wholes this was problem for our. Easy fix and part is about 35 to 40 dollars.
SOURCE: no heat in either oven
May I please have some more information. How do you know you have electricity, because the display is on, inside lights etc. Have you checked the voltage from the wall? It is possible on 220v appliances that 1/2 of the breaker has tripped, thus all the 110v systems work (like lights) except the heating elements, which are 220v. Because both ovens have the same problem, its most likely a power source problem.
SOURCE: I need to calibrate an electric oven
Probably. There is often a key sequence that will enable a calibration mode. We need the full model number to find the tech info, or you can probably find it in the tech sheet which is normally taped on behind the control panel.
