One of the most critical points to be noted down is that several things can merely happen with a switch, including the Spanning Tree Protocol (STP) issues. You may face the STP issue on Cisco switch when a port has become the non-functional after configuring it. To resolve the STP problem, check the following.
•If you're using the Portfast and having enabled any of those guards' features, then ensure that no other devices are having those protocol units sending that port.
•Check that there are no one-way links or uni-directional links persist.
•Run a shutdown command to reset the port if the problem continues.
Sometimes, you may face the STP issue if the EtherChannel isn't establishing a Port-Channel among the configured links. If you're still suffering from the Spanning Tree Protocol problem on Cisco switch, you can ask the more solutions from the experts. Dial the Cisco support phone number to get the immediate solutions.
Cisco Router Tech Support Phone Number 888 604 2301
Reset the router and start from scratch. OR see what commands are in NVRAM
SOURCE: ''!!! WARNING: The switch is not usable !!!''
Unfortunately the show stack isn't showing any results other than it is either a hardware or software fault. I am guessing it is a fault with the hardware as the show version in your first post states "interface Ethernet-controller 4 failed POST POST error status : general error occured".
Ethernet-controller 4 is one if the gigabit ports (poss fibre port), so if you have anything attached to those, disconnect and reboot the switch and see what happens. If that doesn't work, you could try reinstalling the IOS, but at a guess I would say its a hardware fault.
If you have the password logon and type wr erase and reboot.
http://www.cisco.com/en/US/products/hw/switches/ps607/products_tech_note09186a00800c4546.shtml
