SOURCE: Kenmore 80 series dryer stoping after running for 10 to 15 minute
Start any cycle. Dryer runs for 10 to 15 minutes, then stops before cycle is complete. Start again, stops again in 10 to 15 minutes.
SOURCE: 665.15824000 dishwasher
What is your water temp. This model has 4 automatic water heat cycles built in to it and it heats the water to 145 degrees and won't let advance till that temp. If the water coming in is lower than 120 degrees it will add about 2 hours to your normal wash cycle.
SOURCE: My kenmore dryer 66512692 runs for approx. 10
Sounds like your dryer is shutting off due to over heating. There is a high limit switch that will shut the dryer down untill it cools. Make sure your vent is not kinked or clogged, restricting airflow. Secondly, make sure the lint screen is not clogged. Hope this helps.
SOURCE: DU1055XTS wash cycle runs for 1hr 20 minutes then
I am not quite sure if I have understood the problem that you mention.
The dishwashers have several wash cycles and depending on what temperature applies to each cycle the wash cycle time will vary.
My suggestion would be to first try a short cycle like Rinse only and see if that completes. This should last about 10 minutes. Next try Normal (suggesed total time is minimum 71 mins.)
Apart from dishwasher taking longer wash time due to heating water, there is also possibility of some dirt in the wash pump. The dishwasher has got a dirt sensor which checks the amount of soil in the wash water. It periodically lets off some water into drain and takes fresh water. This could prolong the wash cycle. If possible check the chopper assembly (item 6 ) in this diagram. You can work this out if you notice inlet valve operating many times during the wash cycle.
The other thing that can prolong wash cycle is a faulty thermister (item 25). This means it is not giving correct water temperature and the heater could be heating longer. However, at some stage this should trip the high temp fuse. Doesn't seem that this is happening.
YOu have some options to look at. Please accept this solution if you found it helpful otherwise please post a comment.
