Hi there.
see if this link helps you to find out how to do it.
How to unlock the child lock on my whirlpool microwave model no MW 20GW...
SOURCE: Galanz Microwave Oven - Unable to disable child lock
Galanz's website seems to be useless. I tried finding information but kept being told "no data available." So while I can't tell you where to find the manual, here's something to try. Most microwaves get put into lock by pressing and holding one of the buttons for longer than normal, or by pressing one of the buttons several times in a row. Some ovens use the TIMER button. It won't be one of the number keys, but one of the function buttons. So start with a button, press and hold it for at least 5 seconds before you let go. If nothing happens then try another button. If that doesn't solve the problem, then try pressing each function key several times before moving on to the next one. If that still doesn't get it going, maybe a store in your area that sells Galanz will take a look at the book for you. The process should be the same for any similar model.
SOURCE: There is a child lock on our Panasonic Inverter
In my "Panasonic Junior Smart" microwave it's 3 times START to lock and 3 times CANCEL to unlock. Try if that works for your model.
SOURCE: How do I unlock the child lock on my Panasonic
March 2009
press the function key,select option #5, select option#2. This should take it out of child lock. If this doesn't work enclose your model number and I will try to look up the manual
Or, press "Cancel" three times to clear the (child) lock.
You set the lock by pressing "Start" three times.
