Question about Hitachi Televison & Video
Where can I get a remote control for a Hitachi 43 inch smart tv?
Posted by Cecil Anderson on
NOEL
    Top Expert:
  • Hitachi Master
  • 8,546 Answers
5 Related Answers
Vista Electronics
  • 1694 Answers
SOURCE: 43 inch Hitachi UltraVision model # 43UWX10B
Research at www.HitachiServiceUSA.com....................T.
Posted on Nov 10, 2007
Vista Electronics
  • 1694 Answers
SOURCE: problem in Hitachi 43" tv
Common failure called convergence mis-alignment.Needs
convergence IC's replaced by skilled technician.Good set
to keep going a few more years.............T.
Please rate this solution...................
Posted on Nov 15, 2007
jose martinez
  • 159 Answers
SOURCE: need code for hitachi tv
Hitachi: 1145, 0145, 0151, 1904, 0032, 0409,
or you can use the general method:
SEARCHING FOR YOUR CODE
If your device does not respond to the remote after
trying all codes listed for your brand, or if your
brand is not listed, try searching for your code. For
example, to search for a code for your TV:
1. Press TV once.
2. Press and hold P until the red LED blinks
twice, then release.
3. Enter 9 9 1. The LED blinks twice.
4. Aim the remote at the TV and press Power.
The remote sends IR codes from its library to
the selected device, starting with the most
popular code first.
5. If the TV responds, go to step 6. If the TV
does not respond, press CH+. The remote will
try the next code. Continue until the TV
responds.
NOTE: Press CH- to try the previous code.
6. To lock in the code, press P once. The LED
blinks twice.
7. To search for other device codes, repeat steps
1 to 6, substituting the appropriate device
key.
Posted on Apr 14, 2009
frankzcomput
Frank Zabroski
  • 268 Answers
SOURCE: Direct Tv Satellite Remote Control Remote Control: I have a 40 inch rca tv and there are no codes tha...
Try
http://www.remotes.com/
Thanks
Frank
Live-Tech
1-888-361-8511
http://www.mylive-tech.com.
Posted on May 23, 2010
Vaughn Jackson
SOURCE: remote for hitachi 52 inch projection tv not working
My rear projection is our of focus on the left side(double images). I searched for solutions on You tube and was told it's the convergence, and was given instructions.
Is this the correct fix? What do you recommend? Help
Posted on Sep 04, 2012
Codes for a43 inch led onn tv to pair up cable box remote control
google type codes for cable box remote
If you need further help, reach me via phone at https://www.6ya.com/expert/scott_8b3f0f0fc5f566a7
Mar 03, 2018 | Televison & Video
Is hitachi rc4860 is a smart tv
The numbers I am getting indicate it is a
REMOTE CONTROL
for "Various Hitachi" televisions...
Easier to embrace the definition of a TV...
(large thing you point the REMOTE at
Then start looking for WiFi capabilities...
(wireless LAN access)
((presently described 802.11n specifications)).
In my opinion...
Example
NEW Genuine RC4860 RC 4860 Remote Control for Various Hitachi TV Models...
Carnac the Magnificent
Jul 03, 2017 | Hitachi Televison & Video
I have a Toshiba 43 inch projection TV. Six months ago the convergance function was repaired by a TV repairman. Now the TV is periodically turning on and off by itself while we are watching it. What...
More than likely, as the tuning is governed by a remote control function, it is a dodgy remote control.
Try putting the remote control out of the room.
Hope this helps.
Oct 31, 2010 | Toshiba 43HX71 43" Rear Projection...
Hitachi projection TV Model 43F300 has no picture or sound?
did you ever find solution to this? I have similar problem.
Mar 28, 2010 | Hitachi Televison & Video
Connection problem
You can connect via a coax cable from the sat. box to VHF input of your TV and tune on ch 3 or 4 or connect via a RGB cable to component input of your TV or a regular Audio/Video composite cable will connect sat. receiver to your TV use yellow color for video and red&white for stereo Audio then choos the connected input on the menue and watch sat.
May 27, 2009 | Hitachi 43UWX10B 43" Rear Projection...
60.5 inch ultravision rear projection tv - circa 1999-2000
If you provide model number I can suggest correct remote control to buy.
Oct 13, 2008 | Hitachi Televison & Video
Sep 30, 2007 | Hitachi 43UWX10B 43" Rear Projection...
Televison & Video Logo
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
