You would have to either:
Unlock using the same lock-patttern that was used to lock it,
or if , as it appears the unlock pattern is unknown / forgotten,
you would need to take it in to your cell-phone agent, usually with security proof that the phone is yours.
This may include proof of address, ID document, phone purchase invoice, etc.
SOURCE: locked out by too many
1. On the computer: Start PC Companion™.
2. On thecomputer: In the Support Zone™ descriptor, in the Software Updatesection click Start > (Repair) and follow the instructions on the PCmonitor screen.
3. Turn off the phone.
4. Connect the USB cable to your computer.
5. On the phone: Press and hold down Back key and connect the USB cable to the phone.
6. Follow the instructions on the screen.
Note : The software in your phone will be replaced. All personal data stored in your phone will be lost.
There is also a way to unlock the pattern screen lock by signing in with your Google account.
1. After 30 seconds, tap Forgot pattern?
2. You need to log in with the primary gmail.com e-mail address and not the alternative email address connected to the Google account.
3. Tap the username field and enter the primary Google account user name.
4. Tap the password field and enter the primary Google account password.
5. Draw a new unlock pattern and tap Continue .
6. Draw the new unlock pattern again and tap Continue .
If these options are not available to you, please describe preciselywhat you see when attempting to connect to your PC and use PCCompanion.
SOURCE: Hi, I need help, I have SAMSUNG Galuxy S (I9000),
Do this but make sure you may wan't to lose files:
1. Turn off the i9000 phone or take out the battery and reinsert it.
2. Hold the Volume Down button
3. Press and release the Power button
4. Select Clear Storage by pressing the Volume Down button
5. Press and release the Power button
6. Press Volume Up to confirm i9000 MATER RESET
Done!
SOURCE: huawei m860 is locked screen
you should be able to attempt to unlock again after a set period of time. On my phone it is 30 seconds I have to wait after three failed unlock attempt. If that doesn't work then i would suggest going to the Huawei website and look at the FAQ.
I was forqet my google account the username & the password .. PLEASE HELP! :(
You are then prompted to create a new screen unlock pattern. If you no longer want to use a screen unlock pattern to secure your phone, tap Cancel.
