Question about Boating
NEED IMPELLER KIT PART # FOR 2.5 LITRE V6 2 STROKE SERIAL NUMBER OD145403
MERC OUTBOARD
Posted by Patrick Irvine on
Bill Boyd
    Top Expert:
  • Boating Master
  • 53,812 Answers
Available from any merc outboard service shop
if there is none close , the kit may be generic so mariner pump may fit
talk with outboard shop spares
Posted on Nov 16, 2017
1 Related Answer
John Fourteen Six
  • 2418 Answers
SOURCE: impeller replacing on 1999 merc. 25hp 2 stroke
Should not be that hard. Tape up the ends so you can hold it with out getting cut, (if its ragged or sharp from damage). should be one nut holding the impeller on. If its to tight to hold try air or electric Impact wrench. If its bad you can tap with a hammer to help in removing the old one. If it turned on the shaft you will need to rent a puller. Repost if you need more help.
Posted on Jul 05, 2009
What year is a mercury 35hp outboard motor with serial number2491265.Is the motor 2 or 4 stroke
the serial number begins 2487558 and continues past 2491265 and as the beginning serial number denotes the year , your engine is 1969 model
it shows as a 2 stroke with auto oil injection
check the heads
if the plugs are in the flat of the head and there are no rocker covers it is 2 stroke
talk with a mercury /mariner service center
Sep 25, 2016 | Mercury Mariner Starter, Outboard, 35-40...
What year is a johnson 4 hp outboard serial number b 7643180 model number bj4brccs
To get the year of Johnson and Evinrude outboards use the word "INTRODUCES". Each letter corresponds to "1234567890" respectfully. It's best to check with a model year reference book, but this motor's model number contains "CC" which would indicate it's a '88.
Sep 21, 2014 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
9.9 merc outboard serial # 114058 what year is it ?
The best I can tell the year would be 1986.
Is the Serial number A114058?
Jul 03, 2014 | Computers & Internet
Mercury 9.9 outboard 2 stroke Serial number OD127396
by removing the connecting bolts and shift rod connector
May 30, 2014 | Boating
How do i replace the water pump in a 2005 150 hp evinrude outboard motor
Take the cowling off. Also drop the foot. There wil be a stainless linkage rod that runs the length of the motor that you will have undo to drop the foot. The water impeller will be inside a stainless casing that you will have to disassemble.
Aug 17, 2012 | Boating
Impeller replacing on 1999 merc. 25hp 2 stroke
Jul 04, 2009 | 1999 Honda XR 600 R
Boating Logo
41 people viewed this question
Top Boating Experts
ray gallant
 vpsoccer
vpsoccer
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
