Im mechanicaly inclined so i learn quick, like here i learned i should of pre marked the cams, oops
If you are a fast learner then this is the next lesson
go out and but a workshop manual
In it you will find how to time the cam shafts , torque tensions if the engine is an interference of free wheeling ( if it is interference you will have to back off all of the valve clearances or remove the cam shafts until you get no 1 piston tdc as moving the cam shaft to get timing marks correct will bend valves and you will have to start the project again
SOURCE: NEED TIMING MARKS 2.0L DUAL CAM FORD CONTOUR
the cam marks are on the cams under the valvecover the crank has a mark o nthe timing cover that you need to line it up to
SOURCE: valve timing
your bike has a roller cam,there is no setting.
just set timing right.
bye your marks.
you can e-mail me@[email protected]
my name is freebird am 50 years old and been working on cars and bikes for 33 years.
SOURCE: 95 Eagle Summit 1.8L cam timing marks
get a repair manual there must be a mark or reference point of some kind
I do not have a diagram but i do have a site with very detailed instruction on how to set the whole thing up correctly, just click HERE
