Question about Bernina Sewing Machines
The needle displacement lever on my Bernina Favorit 740 will not stay in the center position. It sews in the right or left needle position but the zigzag won't go across the entire width.
R.A. Ellis
  • Bernina Master
  • 12,731 Answers
The machine is probably seizing due to old oil that has dried. Different mechanisms can be affected, including zig-zag, stitch selection, but in your case has affected the needle position.
Wheel on right side that controls the needle up and down is very tight...
Posted on Jan 20, 2018
manicmike519
    New Friend:
  • 4 Answers
I have a 730 (Record) but the mechanism is the same.
There is a spring loaded positioning 'finger' that pushes against a shaped 'rest' to keep it in place, and over time these seize up. Yours has probably seized while pushed in, meaning it doesn't hit the rest at all. I've attached a picture with a red arrow showing the finger.
You need to get it freed to get it to work again. Every 1960s Bernina I've seen has had the finger stuck in the central position, as well as having the positioning dial also seized, so it could be a lot worse :-)
The needle displacement lever on my Bernina Favori - bernina_needle_position-kqvjeiymjisq1nia145cfjlk-3-0.jpg
Posted on Jan 19, 2018
5 Related Answers
Anonymous
  • 57 Answers
SOURCE: How do I change the stiches?
You can do all of these stitches by using different combinations of your stitch selector, stitch width and stitch feed knobs, for instance, on the panel I can see on your machine:
http://www.jo-ann.com/joann/product/images/52659.jsp?CATID=cat3122&PRODID=prd11333
Stitches 1, 2 & 3 are straight stitches, centered, left and right. Really basic stuff, not different stitches at all. 4,5,6,7 & 8 are zig-zag stitches of different widths. 9 is the widest zig-zag (no. 8) on a finer stitch length, etc...
I think you should try and get an instruction manual for your machine. After a lengthy search of my usual manual sources, I've determined that that this may not be so easy. I think you should contact White on their 800 number and let them try and help you... 1-800-331-3164.
If you found this helpful, please vote generously as I receive nothing other than acknowledgement for my time.
Posted on Mar 08, 2008
Anonymous
  • 1027 Answers
The brother website has a users manual for it that can be downloaded. Use this link to get it:
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=hf_ls2125eus&type2=5&flang=English&dlid=
Posted on Jul 10, 2008
Anonymous
SOURCE: Singer 5050
I was hoping you would have got another answer, I have a mechanical sewing machine ( Singer 5040) with the exact same problem. However, if i use the programed stitches I can sew a zigzag. If i do it manually and set the zigzag width to any width ( even the widest) I get only the same straight stitch, and no mater what length I select it is the same too, very close to gether about 1 1/2 inch stitch.
I took my entire maching apart to expose inside both top side and underneath, nothing apeared loose or broke and i oiled it up. I bought a new bobbin holder and still the same effect. So it has to be something serious is my conclusion...sounds like a trip to Sears to me...LOL
Posted on Oct 17, 2008
PABLOCSA
Pablo Csaky
  • 1124 Answers
SOURCE: Trying to sew a buttonhole
You can get all the info of alignments and features of your machine here:
Manual of your machine:
http://www.sewingmanuals.net/bernina-910-sewing-machine-service-man.html
https://www.sew4less.com/product/140/Bernina_910_Instruction_Manual
http://sewingwishlist.com/bernina.html
This information is available online but not for free.
Thank you for using FIXYA!
Dont forget to rate my help!
Have a great day!
Pablo :-)
Posted on Oct 18, 2008
Anonymous
  • 9 Answers
SOURCE: Kenmore sewing machine 385.1960180, problem with needle centering
That sounds like it's definitely an internal adjustment. The machine will need to be opened up and the left/right adjustment taken care of. Is this machine one that you can open the top easily, or is it the type that has the front and rear shell?
Posted on Feb 21, 2009
Needle position problems
Please tell us the make & model machine.
Aug 14, 2017 | Sewing Machines
I'm trying to get my Grandmother's Bernina Favorit 740 running again. I cannot get the zigzag lever to pull down so buttonholes can be made. Any suggestions?
The lever could be rusted in place; ie. the parts that move across/over each other when the lever tries to move down, don't.
Here is a list of Internet searches for Diagrams; not all of these will be for your exact machine but all are similar. Cast about and you can see how your lever is supposed to work.
Bernina 740 diagram Google Search
Mar 29, 2015 | Bernina Sewing Machines
Bernina 930 change needle position
Look at the knob which creates the zig-zag stitch (1-4) at the top right of your 930. In the center of that is a silver knob that rotates right and left. That silver switch moves the needle position right and left.
Mar 22, 2015 | Bernina Sewing Machines
I cant get my needle position to move to the left or the right
The long arm is attached to the needle arm.
1. Move the needle arm right and left with your finger. Is there any resistance? There should be. If not, a spring that is supposed to be attached to the long gray rod has came loose.
2. The spring will be attached so it pulls towards the round cogs (bumpy things).
3. Mechanical sewing machines are very similar. There is a possibility that your adjustment lever has screws came loose.
4. By moving the needle arm back and forth you can monitor what is going on to get a clue of what may be wrong.
Mar 06, 2015 | Sewing Machines
I have a Bernina 180 sewing machine that the needle is not coming down?
This might be a bit hard to explain without showing you a video or photos, but here goes.
The 180 and many other Berninas do what is called a basting stitch. When a machine is doing this stitch the needle stops going up and down for a very short time this producing a long basting stitch. There is a mechanism on the needle shaft that has a black short lever on it. When the basting selanoid pushes in on this lever the needle stays in the up position. Simply stated this lever mechanism can stick if it is not oiled and your needle will stay in the up position and not move when the machine is running. Sometimes just pulling the needle shaft down, then letting it go so it snaps back up into place will lock the basting ever back in place. Once you get the needle shaft to lock back in everything will work again.
I can guarantee you that this is your problem if the machine runs but the needle stays in the upper position. I pose helpful Bernina videos on YouTube under the name JoeKind1958. It would be so much easier to show you how to oil the basting assembly on your machine. Contact me through that site and I can make a video showing you what to do.
Aug 08, 2014 | Bernina Artista 180
Bernina 740 favorit timing
boscados 740 840 940 742
Jan 12, 2009 | Bernina Activa 130
Bernina 1630
I have a Bernina Virtuosa so not the same machine - but this may help. There is an icon on the front of the machine - it is a needlepoint pointing at a dot in an oval - there are arrow buttons on either side. These move the needle left or right of center and it shows on LED screen. I checked mine just now and if you turn machine off and on it resets to center automatically. Hope this helps - Happy Sewing!!
Dec 15, 2008 | Bernina Virtuosa 160
Sewing Machines Logo
191 people viewed this question
Top Bernina Sewing Machines Experts
Chris Wetmore
Colin Stickland
Colin Stickland
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
