Question about Electrical Supplies
Generator went into over speed today when it was starting for it's weekly test. What could have caused this and what is the solution? It is a 14KW Model 0058841 Generac Automatic Standby Generator.
Posted by Joe Pasky on
STEVE SPAM REMOVER
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Electrical S... Master
  • 36,397 Answers
You really need to list what generator you have. nobody here is going to guess at that one.
Posted on Nov 13, 2017
Testimonial: "Thanks, Steve!! Appreciate your help! I guess that information would help!! LOL!"
Generac 14kw Propane generator won't start, just buzzes and displays cranking then RPM sensor loss.
if its not cranking clean your battery terminals and check the charge level. also check battery water levels
Jul 14, 2018 | Generac Electrical Supplies
How do you fix generator from going into overspeed?
you have a stepper motor issue. thats why its overspeeding
Nov 13, 2017 | Electrical Supplies
Trying to find what oil filter can be used in 14KW Kohler
what is the filter part number on the Generator now? Give that to an Auto parts place and they will cross it to what they sell
May 05, 2015 | Kohler Electrical Supplies
Generac troubleshooting my generac 14kw generator engine runs why doesn*t it produce electricity
Assuming the generator circuit breaker is on, depending on the model it could be the voltage regulator or the slip ring brushes or both. If it's a portable it could be a capacitor problem.
Jul 02, 2014 | Electrical Supplies
Surging
It definately sounds like a fuel problem, lack of fuel..I assume it is running on LP or natural gas. The hose running from the demand regulator goes to the carburetor/mixer. When it gets to the carburetor, there is an adjustable main jet. It is different on different models, but is usually easy to find. There is probably a screw slot in the end of the screw head and a spring under the head. Start it up after locating the screw and open the jet just enough to even out the running. It was factory set, but barometric pressure and altitude and different fuels in different areas will decessitate different settings.
Please let me know if this fixes your problem, Robert
Jun 27, 2013 | Kohler 30RESA 30kW Standby Generator...
14kw kohler propane generator-sometimes does not start, put battery jumper on and it starts. Battery is new, but had the same problem with the old battery.
The battery charger is defective, as you can start it by jumping it off means it is just a low battery. without it running measure battery voltage, it should be around 12V then plug the charger back in, it should climb to around 13.8B with a good battery. If not have the float charger checked.
Jan 25, 2013 | Kohler 14resa 14kw Home Emergency Backup...
Won't start every time, when it does runs rough
test fuel pump pressure seems like its faulty i think your right
Jan 03, 2010 | 1996 Ford F150 Regular Cab
Generac generator remote start
si tiene transfer automatico solo poner un swicht en hilo 1N para cortar senal de entrada al generador del utility power que sensa la presencia de voltage en caso de falta arranca el generador en forma de prueba
Dec 19, 2009 | Generac 13,000 Watt / 13,000 Watt Home...
Electrical Supplies Logo
110 people viewed this question
Top Electrical Supplies Experts
Gene Haynes
Marvin
Marvin
Are you an Electrical Supply Expert? Answer questions, earn points and help others
