SOURCE: how do i solve puzzle 134 in the bonus section?
134 Land Disputes
1. The feuding parties have demanded that the land be divided into four
identically sized properties. You'll have a much easier time achieving
this if you start all your divisions from the middle of the large chunk
of land.
2. If you find a group of houses or wells together, you know where one of
your proper lines needs to go.
Now you just need to use a little logic to determine where the lines
need to pass through.
3. The division lines for all four properties run through the center of the
map.
You'd do well to try dividing things up further after you've decided how
to allot the four squares in the center of the map.
134 Land Disputes
***XXX
*O***X
*OO*XX
OO@XX@
O@@@X@
OOO@@@
Thanks and please take a moment to rate as fixya.
SOURCE: I've finished the game but haven't found all the puzzles
When you get to the top of the tower you have the option of going into the house or return to the village,In the village you will be able to complete Puzzles; otherwise go into Bonuses where there are Layton's challenges, & Top Secret.
SOURCE: finding all 120 hidden puzzles...
When the game says that you've solved 131 puzzles, then you've solved 131 puzzles
Players forget that the puzzle index only shows the puzzles that have been found ... just because the last puzzle in the list says 132 doesn't mean that there's 132 puzzles in the list
You have to carefully look through the list to find the missing puzzle number ... if you don't find it look again (some players have had to look through the list multiple times before spotting it)
Once you have the missing puzzle number, check this walkthrough to quickly find where the puzzle is (if it's not in Granny's shack)
SOURCE: Puzzle Master's House won't open
You haven't solved all 132 puzzles
The game tells you (both in the trunk and in the save slot) how many puzzles you've both found and solved
Players who think they've solved all 132 puzzles usually just look in the game's puzzle list, see that the last puzzle there is 132 and mistakenly assume that they must have solved all 132 puzzles
The puzzle list only shows those puzzles that have already been found, not every puzzle
Unless the found/solved count shows 132/132, then the last puzzle house will not open
If the game says, for example, that you've only solved 131 puzzles, then you have to very carefully look through the list to find the missing puzzle number ... if you don't find it, look again (some players have had to look through the list multiple times before spotting it)
http://professorlaytonwalkthrough.blogspot.com/
There's a puzzle index down the right side of the walkthrough you can click on
On a side note, this walkthrough can also be used for more puzzle solving fun, by looking at those puzzles that are specific to the other version (US/UK) of the game (there's over 180 puzzles between the versions)
