Question about Archos Audio Players & Recorders
How do I get code 104 for my archos 405? - Archos Audio Players & Recorders
Posted by Stan Theisen on
UniversalAlmond
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 32 Answers
If you press repair disk it comes up saying connect to computer and update file. i do this. then the repair disc comes back on again as above.i press format and it goes off but not come back on yet.
Posted on Nov 12, 2017
  • UniversalAlmond Nov 12, 2017
5 Related Answers
Anonymous
SOURCE: pi would like to get my player back,pls...
hi
it u hav archos 405, go to archos .com >support>download>select diretory product input u archos model>download the firm ware and put it in no folder wen u connect u device with the pc
Posted on Nov 20, 2008
Anonymous
SOURCE: code 104
Recovert code 104
would you like to recover your system?
NO
Repair disk
Format disk
P.S. pressed the OK button on the device and its telling me to
connectto your divise to my PC and install an update file DONE
then the devise reapear back to recovery code 104
Posted on Jan 16, 2009
Anonymous
SOURCE: recovery code 104 for the archos 405 mp4 player
go to archos firmware and download version 2.1.04 to your pc or laptop and save it in a folder then get ur mp4 turn it on and go format you will get a screen that says done leave it on that and connect to your pc or laptop it will recognise your mp4 then go in my computer and open 405 and open your save file and drag the save file into the 405 but NOT into a folder below them and after it has\copied turn the 405 off and start it up should be as good as new
Posted on Feb 01, 2009
Anonymous
SOURCE: i have an archos 405 and all i keep getting is recovery code 104
what is website called for archos
Posted on Jan 17, 2010
Anonymous
SOURCE: 405 Digital Media Player: recovery code 104...
come si fa a ripararlo
Posted on Jul 21, 2010
Recovery (code 104)
From Archos' support website FAQ:
When I switch on my Archos device, the following message is displayed: "Would you like to recover your system?" What does it mean and what should I do?
You are on the recovery mode screen. It means that your hard drive has been damaged and must be repaired or formatted.
With this system recovery mode, you will have to select between "Repair Disk" and "Format Disk".
Start by selecting "Repair Disk" and follow the instructions displayed on the screen. See the full PDF manual (available on the Archos web site) on how to use the Repair and Format options.
If repairing the disk did not work, try formatting the disk by selecting "Format Disk". Note that the formatting will erase all data.
If you still cannot restart your Archos after trying a system recovery, you should contact Archos technical support.
http://www.archos.com/support/support_tech/faqs/en/faq_Archos405.html?country=us&lang=en
Feb 17, 2011 | Archos 405 Digital Media Player
Archos 405 blijtf gaan om de hertel [code 104] wat moet ik don
http://www.archos.com/support/support_tech/faqs/en/faq_Archos405.html?country=nl&lang=en
See:
It means that there is a hard drive error due to damage. The hard drive can be repaired by selecting 'Repair Disk'.
I tried to translate this for you using Google Translate, but Fixya would not allow it.
Good luck from Detroit, MI, USA.
Jan 05, 2011 | Archos 405 Digital Media Player
Hi i have a archos 405 and it goes to recovery code 102 and will not repair or format disk any ideas on what to try?
Iv had this go to your Archos and do RECOVERY Then go to your computer load the Archos programe. Go to you archos account and find the updates for your Archos. Right click and SAVE TO YOUR COMPUTER NAME IT Archos 1..Do the same with the secound and third Updates if there are anymore.
Now you will need to see your Saved program which should be on your desktop and your Archos in your MY COMPUTER Reduce both these so you can see them .
Nearly there
Go to my computer Drag and drop the First programe Archos 1 onto the Archos in My Computer Go to your Archos and click OK
THIS WILL TAKE UP TO 3 - 4 MINS TO DOWNLOAD
gOOD lUCK
Apr 25, 2010 | Archos 405 Digital Media Player
Recovery code 104 appears on my archos 605 wifi 4gb
recovery code 102 and 104 appear in archos screen. it doesn't work.
Jun 07, 2009 | Archos 605 Wifi Portable Multimedia Player
Code 104
Recovert code 104
NO
Repair disk
Format disk
Jan 14, 2009 | Archos 405 Digital Media Player
Recovery code 104 for the archos 405 mp4 player
Dec 27, 2008 | Archos 405 Digital Media Player
Pi would like to get my player back,pls...
hi!
go to archos.com click on downloads then click on firmware and follow the instuctions !! =].. i had the same problem!! all my music got deleted but it works again !!!
Feb 29, 2008 | Archos 405 Digital Media Player
48 people viewed this question
Top Archos Audio Players & Recorders Experts
Marvin
Marvin
 Grubhead
Grubhead
Harrie
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
