SOURCE: Washing machine fills, but won't agitate
maytag washer dryer stack unit , model # lse7806ace washer fills with water but won't agitate or do anything else. I had the same problem a year ago and replace the lid switch asssemby and fuse and it worked fine until now. the switch clicks when I open and close the lid and the pink and orange wires show continuity with the lid closed.
SOURCE: GE wcxr1070a washing machine. fills with water
Check the water level switch and the plastic tubing to the switch.
Sometimes soap scum stops up the plastic hose and the water level switch does not close to send power to the timer.
If the plastic hose is good and the water level fills and stops replace the water level switch.
SOURCE: washer will not agitate or spin
HI,
you can view this site to have some ideas about your agitator problem.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes
any further question let me know.
thanks,
SOURCE: water running out when washing machine is filling?
Hi jojolevaokah
Water siphoning out the drain line
If the water is
continues to fill and water is draining while it is filling or
agitating, Check the height of the stand pipe. It should be about 36"
above the floor. If the height is correct it may need to have an
anti-siphoning valve installed into the drain line.
SOURCE: No water is coming in the washer before the agitator starts
The above answer is copied from Washerhelp Please only use small quotes and link to the original source
