Question about Hisense Televison & Video
Tv has sound but no picture
I have hisense tv model 40k20d it has sound but no picture. i can see menu on the screen with the help of flash light
Posted by Abdul R Sirhandi on
Larry
  • Hisense Master
  • 3,157 Answers
Check the backlight circuitry
Posted on Nov 11, 2017
5 Related Answers
Anonymous
  • 556 Answers
SOURCE: Mitsubishi tv model # wd-52527, lamp light flashing,no picture.
I would say so.
Posted on Aug 18, 2009
Anonymous
SOURCE: Phillips 37PF73203 37 in Television goes straigt to Menu and stays
When I turn on my TV it goes straight to the menu screen. You can still hear sound but no picture. When I try to exit you see the picture for about a second then it automatically flashes back to the menu screen. Even if I try to use the functions in the menu screen it flashes right back to the main menu screen. Very frustrated...need help!
Posted on Nov 14, 2009
Anonymous
SOURCE: Hisense TV No picture only Sound
I have the same problem...please assist
Posted on May 10, 2010
SOURCE: TV pictures can't come out
www.rolsen.ru/content/tech/PDH4239EU_service_manual%20V1.0.pdf
www.rolsen.ru/.../PDP32XX%20Service%20Manual%200804301.pdf
use these service and repair manuals, to troubleshooting procedures.
Posted on Jun 01, 2010
Testimonial: "Very helpful"
dduncan774
David Duncan
  • 760 Answers
SOURCE: My hisense 50 inch lcd tv has picture but no sound.
If you still have back light, then the T-con is probably defective. If you don't have back light, then you either have a bad power board/inverter or a defective panel
Posted on Mar 20, 2013
I have a HISENSE 32 LED TV, MODEL #32K20DW -A, SER #32J141913H05831.
If it was me i would check the voltages to the back-lights first and if the voltages are ok i would look at testing the led strips them selfs but if you have never done this before i would recommend taking it to an engineer but if the voltages are not ok change the power board.
Hope this helps.
I need help on how to connect the network on my Hisense smart tv. I don't know the model number or how to find it.
Does your TV have RJ45 connector ?
That looks like
26263581-kbmxcsgdcjwkxkxfv11waner-3-0.png Insert a RJ45 patch cable from the router to that port using taht looks like this
26263581-kbmxcsgdcjwkxkxfv11waner-3-2.png Your TV should AUTOMATICALLY now be on the network
2answers
How can I hoop up an antema to TV?
That depends on the type of antenna, but in general it attaches to the same jack as your cable would. On the tv setup menu there witll be an option for cable or antenna, and then you'll need to run a scan to setup the channels. If the antenna you chose doen't have a ***** on connetor like cable, you can get an adapter at Radio Shack.
1helpful
2answers
1helpful
hello, i've repairing one at the minute with same fault, but you could try this i'm not going to say it will work but can try it. turn the tv off and back on again with the tv on press the menu button while taking the power lead out keep your finger pressed on the menu button and replug the lead back in if it works the menu will come back on the screen you might need to retune it back in. i hope it works
regardsshaun
Televison & Video Logo
Top Hisense Televison & Video Experts
Jean Sintulaire
Ekse
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
