Question about In Office Equipment & Supplies
How many square feet in a 24x24 foot room? - In Office Equipment & Supplies
Posted by Wendy Stahl Frakes on
Bill Boyd
    Top Expert:
  • In Master
  • 53,816 Answers
Use your calculator
24 x 24 = 576 sq ft
to help you out === area = length by width
Posted on Nov 11, 2017
5 Related Answers
SOURCE: I have a new house
HI YOu have a 5 ton unit =60,000 btu=12000 does 500 sqft=2,500 for you no problem.good luck & thanks
Posted on Jun 10, 2011
Brew Meister
  • 62 Answers
SOURCE: 13 feet by 13 feet carpet is how many square foot
169
Posted on Mar 18, 2015
robert
  • 2548 Answers
SOURCE: I need the formula for figuring square feet, say a 12 x 25 foot square---Need to know how much paint would be needed?
12 x 25= 300 sq ft.
Divide that by whatever the paint can says the coverage is.
if paint says 1 gallon covers 200 sq ft then u need 1.5 gallons
Posted on Apr 03, 2015
hichbiri
Huseyin Huseyin
  • 3469 Answers
SOURCE: Square feet
308 square feet but you should get a few square feet extra in case you need to make "cuts"
Posted on Nov 05, 2015
jhnolson
  • 822 Answers
SOURCE: I have a square foot garden 4'x8'x6" how many cubic feet will I need
192
Posted on Nov 27, 2015
How to convert room measurement to square feet?
Measure the length and width of the room (in feet) then just multiply the two numbers to give square feet.
Dec 02, 2015 | Carpet Pro Vacuums
How many square foot of floor panels do I need to cover a room 12 foot x 6 inches x 13 feet in square eet?
To convert your 2 dimensions to square feet you have to multiply them together.
12.5 x 13 = 162.5 square feet.
You do not give the size of floor panels you want to use
To find out how many panels you neeed, divide 162.5 by the square footage of the panel
eg, 12" x 12" panels are (1x1) 1 square foot so you would need 162.5 of them.
24" x 24" panels are (2x2) 4 square foot so you would need 41panels
Aug 15, 2015 | Building Materials
HOW DO I CALCULATE THE SQUARE FOOTAGE NEEDED TO LAY A WOODEN FLOOR?
Hello, width x length,measure the largest portion of the room and if you have a small area like a alcove measure that also then add your totals up. hope this helps
PS I try to convert to feet
Mar 20, 2015 | TA Laminate Sierra Maple Flooring
I have a 14 x 14 foot area how many square feet of flooring do I need
The general rule of thumb is to take the area of the room plus 10%. However, if you are not covering the entire area (say you are not going to floor underneath an island, let's say), you can deduct that area. 14x14 = 196 square feet + 10% (19.6 - say 20 square feet), means you'll need 216 square feet of flooring.
Mar 04, 2015 | Dream Home - Nirvana PLUS 10mm Ashford...
Turn 675 squared feet into room dimentions
You can devide it up how you want. 675 squar feet is like having 675 one foot by one foot squars so a room that is 10 foot in one direction and 10 foot in another is 100 square feet so 6 of those would be 600 square feet and say a room that was 7.5 foot by 10 foot would be 75 foot
Feb 14, 2015 | Office Equipment & Supplies
What is the comparison of heating 1500 cu. ft. to 1000 sq. ft.?
a cubic foot is a 12inch by 12inch square by 12inch depth its like stacking 1500 little sq. boxes in a room or two.a 12ft by12ft room with 8ft walls would hold 1152 cubic feet or little boxes.so in comparison 1500cu ft is little more than one room,1000sqft is a small house.
Feb 03, 2015 | Leisure HOMEPRIDE Electric Fireplace...
What is 9600 cubic ft converted to square ft?
Cubic foot is a unit of volume. Square foot is a unit of area. There is no direct conversion between them.
A 9600 cubic foot room with a ten-foot high ceiling is 960 square feet. If the roof is eight feet high, the area is 1200 square feet. If the roof is 12 feet high, the area is 800 square feet.
Jul 02, 2014 | Office Equipment & Supplies
I want to know the total sq foot of a 16'x14' room the total of a 14'x5' and a total of a13'x13' room Or the total of all 3 together. Thanks
If you have a calculator just turn it on and typ[ what follows.
[X] means you press the multiplication key
[=] means you press the = key
[+] means you press the addition key (plus)
16 [x]14 [=] area of first room.in square feet
14[X]5[=] area of second room.in square feet
13[X] 13= area of third room in square feet
If you want to obtain the total area of all the rooms at one go
16 [x]14 [+] 14[X]5 [+]13[X]13 [=]
Aug 25, 2011 | Office Equipment & Supplies
1,950 people viewed this question
Top In Office Equipment & Supplies Experts
Marvin
Marvin
Paul Carew
Are you an In Office Equipment and Supply Expert? Answer questions, earn points and help others
