SOURCE: Ground Fault circuit Breaker trips each time a load is applied
The most likely causes in their order of probability are: 1) water somewhere in the circuit causing the hot wire to ground; 2) a legitimate trip caused by a defect in a device plugged into the circuit; and 3) a defective GFCI breaker. In the first case, wait until it has been dry for about a week and see if it trips. In the second case, make sure there is nothing plugged into the circuit and try resetting. In the third case go ahead and put the regular breaker in, then put a GFCI outlet into the first box downstream from the breaker. If installed according to the directions, that outlet should protect all of the outlets downstream.
SOURCE: Kenmore 417.40412700 tripping GFI circuit breaker
Unfortunatly washing machines are too sensitive for GFI outlet.only way to fix is too take it off the GFI.
SOURCE: ground fault interrupt (GFI)
I have a Whirlpool Model AD$)DSR1 Dehumidifier, with similar issues. When plugged in where it was operating for three years with no problems, it would trip the gfci within 10 minutes. I have it out in the garage right now with all the covers off, and I've had it running on a heavy duty outlet for about a half hour now. The compressor is too hot to touch (ouch!), and the condenser coils are only cool, when they should be quite cold. I am ready to judge that one of two things has happened: Either the compressor is bad, or the refrigerant has leaked out of the system.
SOURCE: trips ground fault on plugging into receptacle
I just opened one of the machines with this issue and found that the heating element is entirely ripped open (over the length of the coiled heating element) and the water contaminated with brownish stuff from within the element.
Was wondering if that part can be replaced.
SOURCE: my de'longhi magnifica coffee maker trips the
Yes it is possible, but here is what you have to do first, try a different outlet, that is not on same circuit , another part of house, even garage. If it still trips breaker, then more than likely it's a machine problem that is causing this. If it doesn't trip, then you can put it back where it was, but then have to maybe move other items on that circuit else where if your fond on that spot for the machine. Espresso machine have a huge surge electric demand when on heat mode. Like all kitchens they have several out let's on same circuit , if you still want it in same area, then have to move other stuff to other outlets that don't share circuit. And no you don't want to up circuit breaker to larger breaker as wires might not be rated to handle larger breaker. Let me know if my idea works, thanks mike from fixya
