"You may need to tip the dishwasher forward, use a towel as water will get every where otherwise. "
This worked! My dishwaser was properly draining, but this time it stucked with the blinking glass light. Powering off/on, didn't work.
I tipped it forward and a little bit of water fell off of the bottom front panel. Pluged it back and it now works! Thanks!
You are a lifesaver! Did everything everyone else suggested and your solution is the only one that worked. Saved me $300 in unnecessary repairs! Thank you!
looks like it worked for me too right now! Thank you.
Yes was having this exact same issue and tried what was suggested and yes water spilled and unplugged and it back to normal thank you so much
Yes I tried the steps here and once I tilted the dishwasher forward I also saw water I unplugged as others did power it on I can choose the program Cycles again so seems to be working thank you so much for the tip as this was becoming a major problem
I did the same with my candy portable dish washer and now it works.
Thank you it works for me too , you saved my life haha
I did once and it worked the next time, but then it happened again. I guess there is an issue with water leaking to the pan underneath. Anyone knows how to get to the pan? or some solution to this?
The dishwasher will allow 2 minutes of fill time before it interrupts the cycle drain and shuts off. It should only take 40 seconds for water to fill. It will accommodate for low water pressure but not after 2 minutes. Open the hot water faucet all the way. Check for any other obstructions such as kinks or debris in water line.
Check that the pump is not blocked and is turning g freely.
The statement below is from the manual. rror Codes:
Speed Cycle Light is Flashing: The water faucet may not be turned on,
the water intake is obstructed or the water pressure is too low.
Glass Cycle Light is Flashing: An area of the unit may be leaking. Turn off the water supply and call for service
SOURCE: Dishwasher--water in bottom -end of cycle.
You may need to tip the dishwasher forward, use a towel as water will get every where otherwise. once drained put it through another cycle. this should reset the drainage level. hope this works as it has for ours, bye
SOURCE: Dishwasher isn't draining
It could be the pump, but not only. Check first that you don't have any clog in the drain line. If drain line is clean, open machine's rear panel and : - Look if the pump works. If it doesn't work check that pump get power (with multi-meter). In case it get power (and does't work), it should be replaced. - In case the pump works - The machine has a drain valve with an electric solenoid (the drain pipe connected to it). When it get power the valve opens and diverts the water to the drain line. Test that it get power. In case it get power and dosen't work - You can easyly open the valve and clean it (from scale or other dirt). Be aware you should disconnect the power cable from machine before doing it !!!!! Check as well for valve's coil resistance. In case you have no resistance measurement - you should replace for a new valve. Good luck !
SOURCE: Danby DDW1802W Cycle Problems
The fill valve is probably stuck in the full position. It's at the bottom of the tub and looks like a small tube with a cap on it. You should be able to move the cap up and down easily.
SOURCE: my danby countertop dishwasher won't drain
the problem has not been resolved. does not drain.
SOURCE: Danby portable dishwasher 1805W hose
First cut the hoses off near where they would connect to the plastic quick adapter. Leave a little slack at 2-3 inches between where you cut and the metal clamp.
Take those two pieces you just cut off to home depot or lowes. Afterwards you can chuck them if you don't want them (I did read below). Take the metal faucet adapter with you too.
For the water supply hose (this is the smaller one) need a Hose barb adapter 3/8 Barb x 3/8 FIP
You need a clamp for this.
Get a plastic hose the length you want and the right barb to fit the drain hose and your new hose. You need two clamps. Also you might consider hooking it up to an external water pump depending on your situation. If the hose is long or has to go up above 36 inches then you may need a pump.
Then you want a standard dishwasher connecting kit. They have them from 4-6 feet, they come with a 3/8 brass fitting make sure you get that.
You also need plumbing teflon.
I also wanted to replace the faucet connector because the plastic one it came with leaked all over the place. I got a quick snap that goes to a garden hose. It fits the metal faucet adapter that came with the dishwasher. . I had to get a few connectors to go from the garden hose adapter to the standard dishwasher hose.
Installation. Take the clamp for the supply hose and put it on the hose connected to the dishwasher. Put insert the barb and tighten the clamp.
Put teflon on the 3/8 male connector that came with your standard dishwasher kit. Connect it to the Barb adapter you just installed. Connect your standard dishwasher hose.
Connect the other end. Its pretty straight forward just don't forget to put teflon on any of the thick threads.
From this you can pretty much figure out the rest with the drain hose.
If I were to do it again I probably wouldn't have used the standard dishwasher kit. I would have gotten a cheap plastic tube and connected it. Also if you're happy with the plastic adapter they gave you save the plastic connectors you cut off and you can use another 3/8 barb adapter to connect it to the other end of your extension hose either a simple plastic tube or the standard dishwasher connector.
After draining the water the unit properly sort of. The short cycle which is supposed to run about 45 minutes takes 2 hours and then it has to be drained again.
I have exactly the same problem!!! Did you solve the issue?
Mine now is also stuck on glassware, reset button hopefully?
