Televison & Video Logo
Question about Curtis Televison & Video
Hi I have a LEDVD1339A-2, I just purchased a new Curtis remote on line it says just install batteries and it should work ... it’s not working PLEASE HELP
Posted by Kelly Lamb on
Larry
  • Curtis Master
  • 4,793 Answers
HI...I assume you ordered the new remote by the model number on your TV if your saying it was supposed to work without any codes being entered, just by inserting batteries.
On your smart phone download the app below and use it to test and see if your tv remote is actually working, if its working chances are you have issues with the sensor in your TV
https://play.google.com/store/apps/details?id=com.ftbdroid.remote
Posted on Nov 10, 2017
Sometime Mechanic
    Habit-Forming:
    Scholar:
  • 122 Answers
Were you not required to enter the TV manufacture numbers from the Curtis' booklet?
5 Related Answers
Anonymous
  • 3130 Answers
SOURCE: my remote control does not work
You could have a defective IR sensor in the tv set that sends the infared signal to the MIcroprocessor IC. These are something you cant just replace, as it needs to be trouble shot with a scope to see if theres a data signal comming out of the sensor and if there is it could be a bad solder connection somewhere between the sensor plug to the Main IC. Also could be the B+ that supplys voltage to the sensor. Unless you have had electronic repoair experience, You should have a pro assist you with this repair. Sorry I couldnt assist you more with this . Good Luck
Posted on Jul 06, 2006
Anonymous
  • 13 Answers
SOURCE: Galaxy 2000 RS Remote Starter
go to bulldog security.com and look for your vehicle under free wiring diagrams
Posted on Mar 30, 2008
Anonymous
SOURCE: Cant find universal remote control code for Curtis DVD Player model 1056
stop buying Curtis BS products!!
Posted on Oct 02, 2008
Anonymous
  • 5 Answers
SOURCE: changed batter remote start not working
Hello, What has happened is your remote has lost its programming.. Just like with most electronics, when something is reset or powered off, or even when the battery dies ....the programming software is lost. The remote has to be reprogramed either by a dealer (suggested) or by an aftermarket outsource..Hope this helps...This could help with almost all remotes.
Posted on Nov 22, 2008
Anonymous
  • 15 Answers
SOURCE: keyless entry remote quit working. Just purchased
Transmitter Programming Notes Transmitter Programming
  1. Start with the ignition OFF, hold down the power unlock button on the door panel. Turn ignition key ON, OFF, ON, OFF. Release power unlock button on the door panel. The locks will cycle once.
  2. Hold down the keyless entry transmitter LOCK and UNLOCK buttons for 15 seconds . The locks will again cycle once.
  3. Repeat step #2 for each additional keyless entry transmitter.
  4. Turn the ignition on to exit the keyless entry transmitter programming mode. Programming is now complete
Posted on Jun 17, 2009
Remote not working. Model number is: RC-WM-101.
if possible, please factory reset the remote and then attempt to get it programmed back to your device(s). If not, then you might take the remote to an tech shop and have them test it on their own devices. That way you can determine whether to purchase a new remote or not. Thank you.
Curtis booklet for tvdvd /i need to replace thr remote control for flat screen tvdvd player curtis Model #LCDVD157A
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites.
http://homenol.blogspot.com/
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts.
Just bought a new Curtis Progressive Scan DVD Player and the remote will not work. I have changed batteries twice. Is this a problem with the remote, or with the sensor?
you can always take it in for a warranty check ( still under warranty)and regardless of a receipt problem the payment details will be on the retailers records as to when you purchased it .
I have a model ledvd1339A I need a new cord plugs in tv and then the wall mine has stopped working must have a short.how do I purchase one
If this is the item you are looking for, it is available from here: http://www.amazon.com/UpBright%C2%AE-Adapter-LEDVD1339A-LEDVD1339A-2-LEDVD1339A2/dp/B00MWI55DU
1helpful
I have curtis mathis model cmc 13005 tv with vhs the universal remote I have for it stopped working what do you suggest. New batteries were put it to the remote it lights up but the tv will not work with...
i had the same problem but i knew the cause (dog stepped on it ) what i did after looking on-line is simply opened the case of my remote (00052d) with the batteries still in and light on the remote and halfway through "popping" the hold clips down one side, the remote light shut off and it started working properly. i think that a case support strut inside was depressing a pad and that might be your problem hope this helps
None of the universal remotes work.,
Try website like 1-800 Remotes Factory Original.Buy the exact remote to the original.
Battery pack for model no. 8017/ curtis portable dvd/cd player
From Curtis' website: "Q: Where can I purchase a replacement DVD battery?
Replacement portable DVD batteries can be purchased for $30 from Curtis International Ltd. Please mail a certified check or money order (payable to Curtis International Ltd) to 315 Attwell Drive, Etobicoke, Ontario M9W 5C1, ATTN: Customer Service Department. Make sure to include your name, complete mailing address, phone number with area code, model number of your unit and part required. "
Weigh you options....a new portable DVD player can be bought for not much more.
2helpful
3answers
Top Curtis Televison & Video Experts
Mike
mark warfield
mark warfield
Are you a Curtis Televison and Video Expert? Answer questions, earn points and help others
