Question about Brookstone Office Equipment & Supplies
I have a Brookstone iConvert mini document and photo scanner. I have charged it for 24 hours and it still won't turn on.
Posted by Nadine on
4 Related Answers
Anonymous
SOURCE: Looking for software to run my Brookstone iConvert
I tried very unsuccessfully to use the software provided with my iconvert. My system even crashed a few times. The provided software, Photo Impression 6, may be good for other things but I was about to send the iconvert back when I decided to try the photo management software I use, Thumbsplus and voila, it works like a charm. You may not be able to do all the retouching and other stuff that the Photo Impression does but I just wanted to get them into my system, then I can do all that work with other software or even with the Photo Impression software.
If you want to get the slides converted and the provided software doesn't seem to work, just try some other photo software like thumbsplus. I have now converted several hundred slides with no problems.
Posted on Jun 05, 2010
Anonymous
  • 62 Answers
SOURCE: Is there an instruction book for the Brookstone iConvert?
Hi, you can download the manual for the Brookstone Scanner here:
http://www.brookstone.com/linkedassetservlet?assetId=323330&languageId=EN
If this answer helped you, please leave a positive feedback. Thanks.
Posted on Jul 18, 2010
Anonymous
SOURCE: When I scan a photo,
The reason it has white lines is because the glass is dirty in the inside. If it has one speck of anything inside the scanner it turns into a line because it stays in that one place as the picture slides over it. So that line is actually a dot that is covering the picture throughout the scan. The solutions don't work. I don't suggest taking yours apart. I took mine apart and cleaned the glass. The pictures scanned fine and then the lines show up again. The real solution is to get your money back if you can. It will do this over and over. It's a design flaw in the scanner. The picture is actually squeezed as it it scanned. As pictures are squeezed against the glass... residue builds no matter how clean your pictures are.
Posted on Jan 13, 2011
ercupa190
ernesto cuadra
  • 12223 Answers
SOURCE: Looking for Windwdos drivers on Brookstone iConvert Photo Scanner (SKU 634394) They are not found on Brookstone's website. Only the pdf manual is available for download.
you must go to the support.microsoft.com and download the drivers according.
God bless you
Posted on Jul 26, 2012
2answers
Image scans, but does not save
1 On iPad goto Settings ->Privacy->Photos 2 Turn on iConvert Scan
5helpful
2answers
I convert scanner won't save document
1 on iPad gpt to Settings, 2 goto Privacy, 3 goto Photos, 4 turn on iConvert Scan
6helpful
Brookstone iconvert not saving getting errors
On iPad goto Settings -> Privacy-> Photos
Turn on iConvert Scanner
Scanner is jammed
Try inserting another document to push the photo out
3answers
Saving scans on I convert
On iPad goto Settings-> Privacy -> PhotosTurn on iConvert Scanner
I need software for iconvert software for a scanner I bought at brookstone. It did not come with a cd. Please help me
I had the same problem I found that the missing CD is downloadable on the Brookstone website.
http://brookstonemanuals.com/
Product number for Brookstone "Slide and Negative Scanner" is 598581 ... see back of your manual to confirm.
iConvert Film & Slide Scanner (598581) iConvert Film & Slide Scanner Drivers for Windows XP & Vista (119 MB)
Worked great for me!
Top Brookstone Office Equipment & Supplies Experts
Ekse
Are you a Brookstone Office Equipment and Supply Expert? Answer questions, earn points and help others
