Question about Vizio Televison & Video
My mom has a Vizio HD tv. She needs a wireless headphones because her hearing is poor. Where do I find this.
Posted by Stacy Howard on
Larry
  • Vizio Master
  • 2,800 Answers
5 Related Answers
Anonymous
SOURCE: tv sound
Read the manual for your TV or just stumble around in the TV's menu until you find audio preference options that will allow you to couple or uncouple your headphone-out-jack audio volume from the speakers. Good Luck.
Posted on May 20, 2008
JL Thompson
  • 155 Answers
SOURCE: RS120 Can still hear TV when headphones are on
Ok.. first.. the simple thing is to go into your television menu and turn the television speaker OFF.
Then exit the menu and turn the volume up.. try your headphones now.
Next.. check the back of the TV for a FIXED AUDIO OUT.. plut your headphones into these outputs.. if you have these.. you can simply turn the set down.. and use the volume control on the headphones.
Posted on Apr 24, 2009
Anonymous
  • 42 Answers
SOURCE: hearing headphones hooked up to hd tv which has to run on component and has no sound now
What connecttion on the TV are you using to connect the headphones?
If its the Component Audio In, this wont work as its only an input not an output. If your TV has a headphone connection, use this.
Posted on Jul 16, 2009
tvtek
Duke
  • 1284 Answers
SOURCE: vizio pixelation in hd nt all channels
Usually a TV that pixelates only on some channels is a problem with the signal levels coming into the TV or the cable box. If you are using a cable box then definatley the signal is the issue..
Posted on Nov 11, 2009
tomcattech17
tomcattech17
  • 215 Answers
SOURCE: NEED INSTRUCTIONS FOR HOOKING UP
From the manual:
1. Plug the stereo audio cable into the headphone jack of your audio
source (e.g., stereo, TV, CD player, DVD, etc.). If your audio source
has two RCA output jacks instead of a headphone jack, use the
supplied Y cable to connect your headphones to the two (red and
white) RCA jacks.
2. Connect the other end of the stereo audio cable to the AUDIO IN
socket at the back of the recharging cradle/transmitter.
3. Connect the AC/DC main power adapter to the DC IN power
supply socket at the back of the recharging cradle/transmitter. Then,
connect the adapter to an electrical outlet.
Important: This power unit is intended to be correctly oriented in a
vertical or floor mount position.
Manual:
http://audiovox2.info/docs/common/AW772/AW772_OM.pdf
Posted on Jun 10, 2011
There is no bluetooth listed under my devices on my new Vizio D43-D1 tv. Can I connect it to Bluetooth speaker?
Unfortunately, you can't connect Bluetooth speakers to this TV. You can connect a wired sound bar, home theater sound system (receiver and speakers) or wireless headphones with a wired based station (RCA or digital audio input from the TV's audio out). These wireless systems use RF or Bluetooth signals to the headphones. See this page, http://stereodevelopment.com/#what-are-wireless-tv-headphones , for a few models of wireless headphones that will be compatible with the D43-D1.
I wish that I had better news for you. You may be able to find an audio receiver that supports Bluetooth. However, these usually are Bluetooth devices, the same as the Bluetooth headphones. They can't pair and send a signal to your headphones.
Feb 28, 2017 | Vizio Audio Players & Recorders
I bought wireless headphones, how do i connect them to the TV wirelessly
Normally the wireless headphones have a transmitter that send audio via wireless to the wireless headphones.
The transmitter needs to be plugged into the headphone outlet on the TV. This will switch off the speakers on the TV and sends the audio to the wireless headphones.
Sep 23, 2012 | LG 32LG30 32 in. LCD HDTV
How do I hook my Bose up to my vizio HD tv?
I have a Bose headphone and a Vizio HDTV. How do I hookup the headphones to the TV?
May 01, 2011 | Bose Wave Radio
How i am connect Wi Fi or internet to my TV.it is vizio and model number is J V 50 P HD TV 10 A. and Serial number is PHLANCJ2804679. I WANT CONECT WITH INTERNET FOR NETFLIX PLEASE LET ME WHAT CAN I DO.
As I type this, I am using my Vizio 50" plasma. All you need to do is ditch your current monitor you use for your internet service and use the same cord from the monitor to plug it into your RBG port on the back of your tv.
Next for sound there is a 1/4 jack next to the RGB port on your tv. Connect your tv to your audio out on your computer. (headphones or aud out)
Select RGB on your tv, and your good to go. I bought a wireless keyboard and mouse for my computer which makes it more convenient.
Apr 19, 2011 | Vizio P50HDTV10A 50 in. Plasma HDTV
How to connect headphones
  1. This TV doesn't have a standard 1/8" stereo jack, so you must use the RCA connectors on the back of the TV.
  2. Purchase a 2xRCA Male / 1x3.5mm Stereo Female Y-cable, such as the one available here.
  3. You will also need a set of headphones, preferably a powered set.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jan 20, 2011 | Vizio E420VL 42 in. HD-Ready LCD TV
Can I hook up the Bose Companion 2 series speakers to my HDTV and get acceptable sound?
Well if you currently find the sound of the Bose acceptable and your inbuilt HD TV speakers poor, then the answer is yes. Should you not like the sound of the Bose, plugging them into an HD TV won't make them sound any better :-)
Just use the headphone out of your HD TV to connect. You may find you need to enable the headphone socket/volume via the menu settings on your HD TV
Dec 14, 2010 | Bose Companion 2 Series II Multimedia...
I have new RCA model VHP141 Headphones but will not work with my new Vizio TV. Where do I plug them in the TV?
Visio might not have a headphone jacks at all! Look around your set and, probably you won't find jack marked as headphone. You might need to use wireless headphones, what have an rca plugs and connect them to audio monitor out on your tv set.
Alex's TV Service,
Philadelphia, PA 215-806-5980.
Jan 21, 2010 | Vizio VO47L 47 in. LCD TV
Hearing headphones hooked up to hd tv which has to run on component and has no sound now
May 25, 2009 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Tv sound
The headphones work fine, but the sound on the tv won't turn off. Any solutions to this problem. I have a SonyWEGA tv.
Jan 26, 2008 | Sony MDR-RF970RK Headphones
Televison & Video Logo
55 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
