Question about Honda Electrical Supplies
Generator has spark and fuel fills float bowl but won't meter to passages after cleaning carb
After reading about Honda's Eco Throttle system available on inverter generators it seems it is not a fuel metering system but a computer controlled speed regulator or basically an electronic throttle.
Because the engine of an inverter generator doesn't need to run at a constant high speed to produce the correct 50 or 60 Hz output this generator can run at slower speeds when the load is light. The electronic throttle is the means to make it happen - operated by the computer.
The throttle is probably operated by a stepper motor and the power supplied to it likely to be in digital form. I suggest you try and gain a more full account of how the system works before you delve deeper.
Posted on Nov 09, 2017
SOURCE: How to connect a Honda EU3000is Generator to run the home furnanc
In shor NO.....
1st item to buy if you must conect to your house is a change over switch.it HAS TO ISOLATE THE MAIN LINE TO THE HOUSE< OR YOU WILL KILL SOME ONE....the other thing you have to know is the house just a single phase or a multi.....to save you life and the lines man working on the line when you run your genset, get a contractor to do it....
Posted on Feb 01, 2009
SOURCE: Honda EU3000is Generator is running poorly.
Can anyone help me with the eco-trottle switch when I switch it on it seems to run the same idle whether I have it off or on, what could be causing it not to work, is it a bad switch or I am running 89 octane could that be the problem.
Thanks
Alex
Posted on Oct 09, 2009
SOURCE: Honda generator ei3000. Will run only a few mins
Tank filter not blocked? (Take tap off tank) Enough oil in motor? Try overfilling it slightly
Posted on Oct 23, 2009
SOURCE: Clarke/Honda 700 watt generator ronning slow,
Either the intake valve is not sealing like it should, or the rings are worn, and crankcase vent is dumping the pressure into the carburetor.
Posted on Jun 30, 2010
SOURCE: i have no fuel at
Make sure you have flow from the tank to the carburetor. Also, when you cleaned the carburetor, there are several jets that have to be open in order for the fuel to "flow" through the carburetor. The carburetor on this generator has a pilot jet located on the top side of the carburetor and a main metering jet that screws into the very bottom of the carburetor and will be visible when the bowl is removed. After the main jet is removed there is a main nozzle that also has holes in it that have to be open also.
Another problem that is possible is compression. If the engine does not have sufficient compression it will not "pull" the fuel into the combustion chamber on the intake stroke. Hope this helps to get you in the right direction.
Posted on Feb 19, 2011
Nov 03, 2013 | Honda 3000 Watt Portable Generator
Aug 14, 2013 | Garden
Jun 11, 2013 | Toro Power Lawn Mower
Sep 12, 2012 | 1986 Honda VT 1100 C
Jun 17, 2012 | Toro Garden
Jun 04, 2012 | Toro Super Recycler Super Bagger Lawn...
May 14, 2012 | Troy Bilt 5.5hp Self Propelled Mower
Aug 27, 2011 | Honda Electrical Supplies
Aug 26, 2011 | Coleman Powermate Premium Plus 6250W...
Aug 26, 2011 | Honda Electrical Supplies
667 people viewed this question
