Question about Health & Beauty
Trying to change a Polder digital kitched scale from grams to pounds and can't find manual
Posted by Mary Hobert on
Tom Chichester
    Top Expert:
  • Health & Beauty Master
  • 57,273 Answers
Try Googling (Polder)(model)(manual) without parens.
Posted on Nov 09, 2017
5 Related Answers
Anonymous
SOURCE: setting is in metric instead of pounds
On my model, there is a button on the bottom that slides back and forth to choose the wanted setting. My scale is about 5 years old.
Posted on Nov 21, 2008
Anonymous
SOURCE: i have a set of hanson kitchen scales and i cannot
To switch your Hanson kitchen scales from ounces to grams, press the on/off button until you see the display change to the measuring scale that you require. This change option is ONLY available as you are switching on the scales, so if it already on - switch it off first and start again from scratch. Once you have set it to grams, it will remember your choice for next time, so you don't need to worry that you have to do this every time you switch on.
I hope this helps. Good luck.
Posted on Mar 13, 2010
Anonymous
SOURCE: Have a Chefmate digital stainless steel scale. It
Easy! On my Chefmate scale what I have to do is toggle so that "weight" is blinking. Then hit "0" - that is zero. Now you can change back and forth from grams to oz!
Posted on Jul 31, 2010
Anonymous
SOURCE: how do you switch Chefmate digital scale from
toggle so that "weight" is blinking, then hit zero or "0". that's it.
Anonymous
SOURCE: i have a Producx digital scale and I can set the
There is a small switch on the back of mine that says "lbs/kg/stone", and you slide the switch accordingly.
Posted on Sep 27, 2010
How do i change from g to lb on Polder KSC-345-95 Stainless Steel Kitchen Scale
After searching, no manual can be found. You can however contact their customer service using the information from here: http://www.polder.com/contact
Mar 06, 2015 | Health & Beauty
How do I switch from grams to ounces on the Polder kitchen scale?
There is a button on the back of the scale with "g/oz" below it. This changes your scale from grams to ounces or vice versa.
Feb 24, 2015 | Polder Slimmer Digital Scale
I have the thin kitchen scale. After changing the battery, the display keeps flashing. How do I get the scale to work again?
I had the same problem, I am not sure why but it seems like the circuits misfire when you change the batteries (perhaps a capacitor holding a charge or a diode stuck).
I got mine working again when I put the batteries in backwards (trying to discharge any capacitor that might be holding a small charge still) and then hit the power button with the batteries in backwards; then put the batteries in properly and hit power again.
please note that I am NOT an electronics professional and I have no idea if this is harmful to the scale or not, but it worked for me and the Polder scale is working as designed once I did the procedure. Hope it helps.
Jun 24, 2014 | Polder Slimmer Digital Scale
Grams to pounds
One avoirdupois pound is 453.59237 grams. One troy pound is 373.2417216 grams.
May 13, 2014 | Seca 345 Digital Scale for Babies and...
Manual
You may download a copy of the manual here.
Mar 02, 2013 | Royal DS3 Exacta Electronic Postal Scale...
Lost my instruction manual for Polder Digital Therm/Timer/Clock and I can't remember how to set it.
I'm not sure which model number you have.
Polder timer manuals appear on following link: Click on timers and thermometers.
http://www.polder.com/productinfo.html
Jul 04, 2011 | Polder Triple Digital Timer Model 891-90
Lost Manual of 898-90 Polder Timer
Typical 898 manual:
http://polder.com.p2.hostingprod.com/images/instructions/898_instructions.pdf
Take a moment and vote on answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Dec 09, 2010 | Polder Triple Digital Timer Model 891-90
Have a Chefmate digital stainless steel scale. It weighs in grams and ounces. It was changed accidently to grams but I want it in ounces. Not sure how to do it and misplaced owner's manual.
Jun 25, 2010 | Microwave Ovens
Health & Beauty Logo
1,408 people viewed this question
Top Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Are you a Health and Beauty Expert? Answer questions, earn points and help others
