Question about Marantz Audio Players & Recorders
Thermal cutoff is operating. There is excessive heat being generated on the heat sinks of the Amp. This happens when there is a shorted output transistor or a speaker load changing.
Posted on Nov 09, 2017
SOURCE: Marantz SR5200 - front speakers not working unless direct
If you try and unplug it at least 12 to 24 hours and it does the same thing, then its time to take it in to the shop.
Posted on Aug 26, 2006
SOURCE: Marantz SR5200 receiver works only with remote not manually
Check for a stuck/jammed switch, press each switch if one doesn't make a normal click sound or it doesn't move at all that's your problem.
If that's not it check the owners manual for how to reset the receiver (not all manuals will tell you how to reset it) Another way to reset it is to short the memory cap, but that is better left to a tech.
Posted on Feb 13, 2009
SOURCE: No sound out of speakers (Marantz SR5200 receiver)
sounds like you might need to open it up and check the speaker wires that you plug your speakers up to it might be lose or something else like that cause it happened to me before and that was it.
Posted on Feb 21, 2009
SOURCE: my marantz sr5200 dont reproduce dobly digital
I have the Marantz SR5200, unable to get the Set-up / t.tone button to work, don't have the instructions,
Posted on Jun 21, 2011
SOURCE: MARANTZ sr5200 Left Speaker larger sound right speaker
If you are saying that the left side is LOUDER than the right it could be DC offset on the recording or it could be phasing issues.
Posted on Feb 15, 2017
Testimonial: "Yes the First there is no sound in the Front Left Right speakers. I replaced IC CS4391 the left side is LOUDER than the right. Please help Me! Thanks"
