TCL tv no sound picture good but if tv switched off at power point and switched on sound is there for about 5 mins and then stops working picture good at all times.
Posted by Dennis Stock on
Larry
  • Televison & ... Master
  • 2,800 Answers
Unless the sound is getting muted and the speaker icon shows with the arrow through it its a main board failure
Posted on Nov 09, 2017
Testimonial: "Main board sounds most likely thanks"
lolthepcman
    Sergeant:
  • 179 Answers
Sounds like a SLEEP timer or SNOOZE timer setting,
  • Larry Nov 10, 2017
    That would turn off the entire TV...not mute the sound.
5 Related Answers
ctf1800
Cary Farah
  • 4402 Answers
SOURCE: TV Quit working
5 blinks = IC4011 however doesn't always mean ic is bad.
Posted on Feb 01, 2008
Anonymous
  • 155 Answers
SOURCE: Vizio 42", have picture for about 5 mins then screen goes black.
also check the power cord wire coming from the back of the tv is loose from the tv side or perfect.
Posted on Oct 26, 2008
Anonymous
SOURCE: oven switches 'itself' off without the timer
I sorted it it is a simple solution, if you take the top of your oven you should see the problem...it will be big and black..dont spend a ortune getting it sorted i brought the part off ebay for less than a fiver.. just cant remember what it was called..very simple to fix though.  Mike
Posted on Jan 09, 2009
muttandjeff
Allen Neal
  • 359 Answers
SOURCE: TV power light comes on but no picture/no sound
chip on ic board repair shop might replace it and reprogram if the tv is worth the fix
Posted on Feb 06, 2009
Mike Matkovic
  • 125 Answers
SOURCE: Green Screen
Hi, how is the cable box hooked up to the TV? Is it HDMI cable or componet (red/green/blue) ? When you say totally green, do you mean the the picture is only green with the other colors missing or every color looks green ?
Posted on Mar 14, 2009
Tcl tv freez no sound/picture
are you using a cable box, tried to reset the box.
Oct 13, 2012 | TCL L32D20
Oct 26, 2008 | Vizio Televison & Video
Luxor tv no picture or sound
Connect the TV to another power outlet that you are sure, works. Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | Televison & Video
TCL TV Model: 21K77 Schematic Diagram
NO PICTURE NO SOUND WITH ONLY INDICATION OF POWER STAND BY LED LIGHT
Aug 30, 2010 | Televison & Video
I have an Hitachi digital set top box which i leave switched on.When i switch on the television it takes 5 to 10 min for the picture to materialize and then stabilize into a good image.What is the problem?
Some component(s) is/are having to heat up, to a point, so that it's value changes & as it does so, gets to a point where the set stabilizes, and works. Thermal faults are real hard to find.. Although a good application of Can Freeze Spray can soon sort out your "Bad" component(s)
Feb 15, 2010 | Televison & Video
Panasonic PT-43LC14
The TV shutdown error code can help you with this problem. If the power led flashes green for 2 Min's then red. The Lamp led should flash red 1-2-3 or 4 time every 5 Min's. These are error codes that may point you in the right direction to you problem.
May 24, 2009 | Panasonic PT-43LC14 Television
My TCL 2027U's child lock in on and I can't unlock it
kapag naCHILD LOCKED tapos hindi na maopen ang TV,,,pero nakastandby sya...sira na din ang remote....
anu pwedeng gawin???
please answer...
THANKS
Nov 28, 2008 | Akira EPM-420A 42 in. Plasma Television
TCL tv
i have tcl satellite tv...the porblem is when i switched on , 5 or more minutes after, the tv unit shut off itself. Sometimes the tv scan its channels first before having picture then shut off after few minutes..varying time when shutting off.....And when using for video movies everything alright....please tell me what to do??...any solutions??..advance thanx to those who could help...
Oct 29, 2007 | JVC AV32F476 32" TV
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
