Question about LeapFrog Toys
How to turn leapfrog my first computer on. - LeapFrog Toys
Posted by danny j silver on
How to fix Leapfrog Leapster 2 electronic board?
Leapster 2 Customer Support ' Online Help, FAQ, LeapFrog ...
www.leapfrog.com > Support > Products
LeapFrog EnterprisesVisit our customer support page for LeapFrog's Leapster 2 for help and answers to your product questions.Missing: electronic ‎board
How to fix Leapfrog Leapster 2 electronic board? - Fixya
www.fixya.com/support/t26040145-fix_leapfrog_leapster_2_electronic
35 mins ago - ... 2 electronic board? I know how to solder and basic principles ofelectronic parts. Know - LeapFrog Leapster 2 Learning System question.
LeapFrog LeapPad2 Explorer Troubleshooting - iFixit
https://www.ifixit.com/.../LeapFrog_LeapPad2_Explorer_Troublesh...
iFixitDrained/bad battery; Bad display; Water damage; Bad logic board ... Instructions toreplace the battery can be found at LeapFrog LeapPad2 Explorer Battery ...
Leapster 2 Quick Fix Tutorial - YouTube
? 3:02
https://www.youtube.com/watch?v=eQayGCjEdgo
Jan 22, 2009 - Uploaded by filterdragon
Tutorial on how to fix your child's Leapster 2. If your Leapster 2has a problem other than the screen not registering the stylis pen, please go to the Leaps... ... Ana E 1 year ago .... 2:34. leap frogleappad repair guide.
Jan 05, 2016 | LeapFrog Leapster 2 Learning System
Tag will not update
try downloading it on another system and transfer it to yours.
Aug 11, 2012 | LeapFrog Tag Reading System
I have lost the cables and cd i need to plug my leapfrog tag pen into my computer. can i buy these anywhere?
Regards, Tony
Jun 13, 2011 | Toys
Hi there I need 2 tune up my didj
Follow these steps To reset the Didj to factory settings and solve your problem:
1) Launch LeapFrog Connect
2) On your computer keyboard, press "Ctrl + Shift + R"
(on a Mac "Command + Shift + R").
This should bring up a window that says "Connect the device you would like to reset"
3) Connect the Didj and turn it on
4) Follow the on screen messaging to reset the Didj
5) Eject the Didj when the reset is complete
6) Recreate the profile on the Didj and then turn it off
7) Close and then open LeapFrog Connect
8) Connect the Didj and turn it on
9) You may be prompted the Didj needs an update. Accept this update
10) Get your parents to sign into the parent account and link a footprint to the current profile.
Mar 04, 2011 | LeapFrog Custom Learning Didj Racing -...
Hi what does error code #1096 fault detail null mean?
Thanks for using Fixia.
Please try below instructions if they help .
You will want to use the LeapFrog Connect Tag Fixing Tool to see if you can resolve the issue. The instructions for Mac, and PC are listed below:
PC instructions:
1. Begin with LeapFrog Connect closed
2. Click here: http://lfccontent.leapfrog.com/cs/tools/LeapFrogTagFixTool.exe for the download executable file.
3. A File Download box should pop up. Select "Run"
4. You will be prompted for a location to download the program to, you will see a message "Unzip to folder"
5. Click Browse and select your desktop as the location to save the folder
6. Click "Unzip"
7. This should create a folder on your desktop named "LeapFrogTagFixTool
8. On XP: Open the folder and double click on the TagFixTool to open
9. On Vista or Windows 7: Open the folder and right click on the TagFixTool and select "Run As Administrator"
10. Connect the Tag Reader or Tag Junior to the computer and turn it on
11. Click the button "Click once to fix your Tag Reader or Tag Junior"
12. Once the repair process is complete, follow steps printed on the screen to close the program and open LeapFrog Connect.
Mac instructions:
1. Download the LeapFrogTagFixTool.dmg and mount the image. File is located here: http://lfccontent.leapfrog.com/cs/tools/LeapFrogTagFixTool.dmg
2. Drag the FixIt application into your Applications folder.
3. Close the LeapFrog Connect application (if it is open.)
4. From the Applications folder, double-click the FixIt application file to open the LeapFrog Tag Repair Utility program.
5. Connect your Tag Reader or Tag Junior to the computer.
(Make sure your toy is powered on.)
6. To start the repair process, click the "Click once to fix your Tag Reader or Tag Junior" button.
7. Once the repair process is complete, follow steps printed on the screen to close the program and open LeapFrog Connect.
Note: Please be sure to be signed into your admin account and are connecting to a USB port directly on the computer, not a port on the keyboard or other hub.
Jul 02, 2010 | LeapFrog Tag Reading System
Have lost the instruction booklet for leapfrog my first computer
Hi!
You'll find the parent guide here;
http://www.leapfrog.com/etc/medialib/leapfrog/clickstart/cs_clickstart.Par.0.File.tmp/ClickStartWebPG.pdf
If the link does not open, go to www.leapfrog.com - click 3-5 years, you will find clickstart first computer in line 4.. - click the photo - scroll down under the large image to find the parent guide.
Good luck! :)
Cathy
Oct 21, 2009 | LeapFrog Clickstart My First Computer
Didj will turn on but Warning screen is just frozen.
I had the same problem. What you need to do is open the Leapfrog connect and then plug your DIDJ into the computer. You also need to plug it in with the AC adapter as this takes time and the first time I tried the batteries died. So plug it in or put new batteries in it. Now just leave it sit plugged into your computer with the Leapfrog connect program open. It took mine almost 2 hours just sitting on the white Warning screen then if finally connected and updated the software and is now working fine. Hope this helps.
Jan 18, 2009 | LeapFrog Custom Learning Didj Racing -...
Toys Logo
82 people viewed this question
Top LeapFrog Toys Experts
Marvin
Marvin
Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
