Looks like I have battery life but tablet goes off
SOURCE: new battery will not charge, shuts down
have you tried connecting it up, leave it for say 8 hours and don't use, try it then?
SOURCE: Battery not charging
how long has it been since the batt was purchased? usually batteries are considered consumable parts. meaning in due time, performance will degrade, laptop batteries should be good for 1-2 yrs, after that it battery hold will degrade. also check your ac adapter, try removing the batt, and turn the system on. if the system works without the batt. then it might be the batt itself thats having issues...
SOURCE: Motion Computing C5 Tablet PC won't power on
Hi! I do understand that you are having the problem on the laptop turning on. Try another option, turn off laptop, remove cables and battery, press and hold power button for 10 secs. Reinsert the cables and battery on the laptop. Then turn it on. If the laptop did not turned on, remove the power cable and turned on the laptop. If still didn't, remove the battery and insert the power cable. If still did not work then check if there lights flashed on the laptop when turning it on. If still does not, then you need to contact the pc manufacturer for repair and possible replacement. Otherwise, if there is light on the laptop, then there might be a problem either the battery or the power cable itself. If there is light on the laptop but no power cable, most likely the monitor did not work simply because the battery works due to the fact that there is light on the laptop. On the other hand if there is light when plugging in the power cable on the laptop, then you need to check and insert another battery if it works. Otherwise you need to replace the battery...
SOURCE: fujitsu siemens stylistic M532 tablet not charging battery
I have just had same problem. Battery on M532 absolutely refused to charge from flat.Tablet worked when plugged in so I downloaded an app killer from android market and killed all but the essential apps then tried again and it seemed top work! Maybe background apps draining battery at faster rate than could be charged?
SOURCE: POLAROID TABLET PMID709 WILL NOT CHARGE
How old is tablet , maybe new battery is needed ???? Is there power at the wall plug your using ???? Sometimes it's as easy as the plug , !!M the charger your using May be bad , do you know how to use a voltage meter to test if there s power coming from it to your tablet ?? More info is needed on this ??
