SOURCE: my screen went white...
LG had a problem with their first screen manufacturers in which caused LG to recreate a whole new batch of LG 8500's The white screen was common for a short while.
As im assuming you all have verizon wireless, Take your phone into the nearest corporate store and have a tech look at it .. If your under warranty and there's no physical or liquid damage to the phone, you can have it replaced for free. If none of that is true then it's gonna either be 50.00 plus tax where applicable or buying a new phone.
But still, take it in .. have them look at it .. just looking at it costs nothing.
SOURCE: Smeg Oven digital clocks
two wires drive the clock itself so trace which these are by looking at the track on the card. join the other two. there may be linking across as well.is it a single oven?
SOURCE: RED, GREEN, BLUE AND WHITE HORIZONTAL BARS APPEARED ON MY SCREEN???
hey, i had the same problem and i fixed it. i took the battery out and saw the 4 golden tabs behind the battery. there was two tabs that u could pull out. i lightly pulled them out a little bit. the problem was that the tabs wouldnt hit the battery to charge it. thats why it put the tri colored screen on the front. also my charger fit into the charging hole in the phone, but it had to be moved around to much that it did not fit exactly. I have been rough with the charger so it moved the inside of my phone around. i put the charger in the phone and moved it around gently around untill the light lit up on the front at the top by the word at&t. after it was completly charged, i turned it on and it worked perfectly. i hope this helps in whoever may have this problem because i know it sucks!
Thanks
SOURCE: i have a yamaha yfm 350 moto 4 the stator was
MMM, fun... for a start the 3 whites should be right no matter which way they go, the other 4 i'd look at whether they have male or female conectors if possible, if they're bunched together etc, two should be from the ignition, and I think the other 2 are pos. & neg for the coil or coil + and one for earth, depending on the wiring of your bike
SOURCE: Everstar Beverage/Wine Cooler HDBC36ID not cooling
I returned our unit to Home Depot with relative ease... I think they were all aware there is a problem with these units.
They refunded the full purchase price (even though I was well past the 12-month warranty period). I put the money toward a GE Profile unit that's a little bigger - more expensive, yes; but it works, priceless!
There are four different types of wine with different
temperatures. Deep red wines should be served in 15-19 Celsius. Light red wine
should be served in 13 Celsius. Sparkling wines and Champaign should be served
in 6-8 Celsius. Dry white wines like rose and blush should be served in 8-14
Celsius.
