How to de activate the childproof lock active in washing machine?
Posted by Mary Ann Nagum on
Door not unlocking Fisher Paykel front loader Wh60f60w. The cycle appears to have completed but the door remains locked well beyond normal lock delay. Is there a manual release?
Have switched this on?
Child-proof lock
? You can protect the appliance from being tampered by activating the child-proof lock.
? When activated, no change can be made to the programme running.
To activate the child-proof lock:
1 Press the 1st and 2nd additional function buttons for 3 seconds.
2 The "C ON" (child lock is activated) symbol appears on the screen.
Note: the child lock symbol will also be displayed whenever any button is pressed while the
machine is child-locked.
3 The child-proof lock lamp on the programme follow-up indicator will light up when the childproof lock is activated.
To deactivate the child-proof lock:
2 The "C OFF" (child-proof lock is deactivated) symbol appears on the screen.
3 The child-proof lock lamp on the programme follow-up indicator will go off when the child-proof
lock is deactivated.
Apr 01, 2017 | Fisher Washing Machines
The display is showing alternating between CL and 0. What should I do?
How To: activate and de-activate child lock on your bosch ...
? 1:20
www.youtube.com/watch?v=lTXcTpalob4
Dec 24, 2012 - Uploaded by whichwasher2007 ... activate and de-activate child lock on the bosch logixxwashing machine range. ... you can turn the dial to '0', and thechild lock is still on, when your kid messes ... How to Identify anError Code on a Bosch Washing Machine ...
Oct 03, 2015 | Washing Machines
Fisher & Paykel dryer DE60F60EW1 has suddenly stopped working when I tried to change the program. How do I reset the machine
Here are a couple of possible reasons it stopped and solutions from the manual.
Adding/removing laundry in standby mode
If you want to add or remove laundry into/from your machine after the drying programme has
started, put the machine into Pause mode by pressing the START/PAUSE/CANCEL button. The
drying process will stop. Open the door at Pause position and close it again after adding or
removing laundry. Press START/PAUSE/CANCEL button to start the programme.
Any laundry added after the drying process was started may cause the already dried clothes in
the machine to intermingle with wet clothes and the result will be wet laundry after the drying
process is over.
It is not recommended to add laundry after the programme is started as it will increase the
programme time and energy consumption.
Childproof lock
There is a childproof lock to prevent any programme interruption due to the pressing of keys
while the programme is on. The loading door and all keys except the ON/OFF key on the panel are
deactivated when the childproof lock is active.
In order to activate the childproof lock, press on the StARt/PAUSe/CANCel and BUzzeR CANCel
buttons simultaneously for 3 seconds.
Fig.6 Using the
childproof lock
To start a new programme after the programme is over or to interrupt the
programme, the childproof lock should be deactivated.
To deactivate the childproof lock, press the same buttons for 3 seconds.
Two beeps will sound when the childproof lock is activated. A single beep
will sound when the lock is deactivated.
I was able to view the manual by a Google search and the third item on the Google search list was the manual, but it would only come up by selecting "quick view", otherwise it would crash the Acrobat reader plugin.
Jun 03, 2012 | Toys
Bosch logix8 comming up with the code nro
Bosch Logixx 8 error code nr0 means - The childproof lock has been activated.
Just deactivate the childproof lock.
Apr 10, 2012 | Bosch Logixx WFT 2806 Front Load...
Childproof lock active massage when i press start!!
Just take the power supply pull the plug from the wall socket and just leave it for couple of hours and put it back again.
Thanks for using FIXYA..
Jul 15, 2011 | Washing Machines
Childproof lock in our laundry machine model logixx 8 is activated and i cant turn it off
Hold the Start/Pause button for 8-10 Seconds.
This usually does the trick.
Kind Regards
* If you found this solution helpful, please rate 4 thumbs up and leave a small testimonial. :-)
Apr 04, 2011 | Bosch Logixx WFR 3267 Front Load Washer
I have siemens washer serie IQ 1431. My door will not open and the washer is full of wash.How do i get the door to open?
Cause The childproof lock has been activated.
Resolution Deactivate the childproof lock. Directions can be found in your instruction manual.
The manual for your washer can be fount at at the following website. You will need the E-Nr number in order to get the correct manual. You can find the E-Nr Number on the rating plate of your home appliance.
Mar 08, 2011 | Siemens Washing Machines
WD12D520GB
IF IT IS LIKE MY 5202 YOU HAVE TO PRESS AND HOLD THE UNLOCK BUTTON FOR LIKE 3 SECONDS. THIS PREVENTS SOMEONE FROM JUST PRESSING THE BUTTON AND ACTIVATING THE LOCK . TRY THE PRESS AND HOLD METHOD AND LET ME KNOW.
Dec 19, 2008 | Siemens WIQ1433 Front Load Washer
Childproof Lock
Hello mine is a WM14S79BUK but i think it works on most recent models with lcd display.
I have to hold the down button on the option buttons for 5 seconds to activate child lock or unlock
it's worth A TRY
Hope this helps
Jun 07, 2007 | Siemens WIQ1433 Front Load Washer
Washing Machines Logo
43 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
