SOURCE: PUSH THE RESET SWITCH PROBLEM
hmm...maybe:
You need to know in which position was camera turned of.
So try turning it on in RECORD OR PLAY position.
It will work then...
SOURCE: picture is upside down
Go into the menu, select "Settings", then "System" and then uncheck the "Ceiling" mode. The image will flip around instantly.
SOURCE: my sceptre television picture is upside down, can
If you select "source" on your remote then enter 7343 it will bring up a factory menu. Go down to 'Other setting' , the setting 'scaler output' should be set to "Normal". This setting flips the display.
SOURCE: flashing timer led
There is no reset button like in the old days. You can reset the microprocessor to it's default state by unplugging the set, let it stay unplugged for 10 or more minutes. Plug the set back and it will reset itself.
You might lose stored channels and settings but they will all be reset to the manufacturers specs. This is true for anything that has a microprocessor (computer) in it.
